If I do it that way it shouldnt be an after thought. Thats why Im not waiting until May to ask these questions. What has everyone else done to beat the heat
kd5edj63 wrote:I know its a ways off before I will need air conditioning, but I have been researching AC and I see alot of problems people have experienced. I have a small $100 window unit I want to use, which is probably a pretty common quest. I have a couple ideas in mind, but I saw where a guy mounted his in the gally. My question on that is, wouldnt the gally need to stay open during use, and if not, wouldnt the butter in the gally melt![]()
kd5edj63 wrote:I'm confused by the multiple ducting. Wouldnt it suffice to run just one hose that blows the cool air.
Edit. I take it the radiator looking thing in the front lower section is whats called the evaporator and air must pass through that to remove humidity. Is that correct
aggie79 wrote:kd5edj63 wrote:I'm confused by the multiple ducting. Wouldnt it suffice to run just one hose that blows the cool air.
A window unit has two air "loops". One loop is to cool the compressor. Typically the intake for this loop is on the side of the A/C and the heated exhaust air is at the rear of the A/C.
The other loop is for the conditioned/cooled air. There is an intake (supply) side which can be either make-up air (fresh air from the outside) or return air (conditioned/cooled air that has been partially warmed and is recirculated back through the A/C). In the installation above one duct is for supply air (the cold side) and one side is for return air. By recirculating the air, the A/C will remove more moisture/humidity from the air than if it the supply air was from the outside and the A/C compressor will not cycle on and off as much. This is how I have our A/C setup. Of course, with the teardrop being air tight (Or pretty much air tight), we leave either the vent of a window cracked so that we don't die of CO poisoning.
kd5edj63 wrote:aggie79 wrote:kd5edj63 wrote:I'm confused by the multiple ducting. Wouldnt it suffice to run just one hose that blows the cool air.
So it would still work if I mounted it completely outside, but only ran one duct, or would it not, or would it depend on where the loops are at on the unit. the unit is Zenith ZW5010YO
http://reviews.homedepot.com/1999/20207 ... ng&dir=asc
