Cheap 12 volt power suply
Anything electric, AC or DC
Postby oakinteriors1 » Tue Oct 15, 2013 8:25 am
Just to power a few lights and a vent fan why wouldn't cordless battery chargers work? I have about 4 of these laying around.. Most are for 18 volts....
oakinteriors1
Re: Cheap 12 volt power suply
Postby SLUG36 » Tue Oct 15, 2013 8:53 am
i would think the amperage output on the chargers would be low. kinda like a trickle charger. they might work good for LED lighting. but, you might have trouble with a fan. :thinking:
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby woodywrkng » Tue Oct 15, 2013 1:20 pm
If there are three terminals in the charger socket, I believe one of them is used to read the battery temperature, and without a battery present I don't know what the charger will provide. Use a voltmeter to see what you've got. If there are two terminals, measure them as well. I would be pretty leary of using 18 volts where 12 volts is expected.
woodywrkng
Images: 35
Postby H.A. » Tue Oct 15, 2013 2:00 pm
H.A.
Postby Engineer Guy » Mon Oct 21, 2013 10:05 am
I hit local Joints like 'Habitat For Humanity' or 'Salvation Army'. Typically, in a Box in the back, they have orphaned Power Supplies. Look for those that have the desired Output Voltage while noting the max Current it can supply, and buy those on the cheap.
For running my 2 lil Emergency Radios on Grid, I recycled some old Cellphone Power Supplies. That +5 VDC ran my ~4.5 VDC Radios just fine. Of course, these Supplies could run +5 VDC USB Equipment, too. Look on line for USB Connector wiring protocol. From memory, the 2 outer Pins are Voltage. The 2 inner Pins are 'sense' Pins for Battery Charging, and can be ignored when using them for +5 VDC Power Supplies. If others have had different experiences, or have different opinions, I'm sure they'll pipe up.
Chargers do what the name says: they monitor and charge Batteries; typically through a 'Sense' Lead[s]. Personally, I wouldn't muck with them. Power Supplies just output 'static' Voltage, and are more what you're looking for.
~Reality proceeds with or without your consensus~
Engineer Guy
Images: 118
Postby alex k » Tue Oct 29, 2013 7:38 pm
i use an extra coleman cooler power supply . when the battery is out of the trailer
i just use a double male plug wire to backfeed it into the 12 power plug
not to be confused with alexk from california
Green Lantern Corpsman
Coleman Keepers 200A Gang
alex k
Images: 34
Return to Electrical Secrets
