Plastic welding
Plastic welding
Postby jandmz » Tue Oct 15, 2013 10:41 am
Does anybody here have any experience with the plastic welder that sells for about $50 at HF?
A fellow camper has a blue tank for waste water that is leaking at one of the seams. It is HDPE. It is not a tank that is pressurized.
Is it something that an amateur can do reliably?
jandmz
Re: Plastic welding
Postby SeaFlea » Tue Oct 15, 2013 1:04 pm
hdpe welding just requires patience. I've repaired a couple of rotomolded kayaks using this method and they still float!
while this link targets the repair of a kayak the principles are the same. 'course, I was keeping water out while you'de be keeping water in... additionally, you can do the repairs without the special tool(s); check out the link.
http://www.kayak-repair-central.com/plastic-repair.html
Hope this helps!
Charlie
SeaFlea
Images: 10
Re: Plastic welding
Postby jandmz » Tue Oct 15, 2013 9:17 pm
Thank you. I think that is exactly what we needed to know. Hopefully we won't melt the tank. I'll let you know how it goes.
jandmz
Re: Plastic welding
Postby GuitarPhotog » Tue Oct 15, 2013 11:03 pm
It leaks now. It can't get worse, right?
<Chas>
GuitarPhotog
Images: 55
Users browsing this forum: Google [Bot] and 9 guests
