How to use the youtube tags...
Threads about the forum, forum software, forum features, etc
Postby mikeschn » Tue Jan 01, 2013 4:41 pm
It's time to remind everyone about the youtube tags that we have here...
Let's say for example you want to post the youtube of the dinoot trailer... and you know the movie id is: flM5ZbG9aVU
just paste the flM5ZbG9aVU and put youtube tags around it, by hilighting the movie id, and then hitting the youtube button.
It'll look something like this: {youtube}flM5ZbG9aVU{/youtube} of course you'll end up with square brackets not the curly ones.
And it'll look like this:
Hope that helps!
BTW, Scott's Dinoot thread is here: viewtopic.php?f=39&t=53118
Re: How to use the youtube tags...
Postby Esteban » Thu Oct 17, 2013 11:43 am
Mike, I've tried to use the Youtube tags several times. I have yet to get them to work. Instead I've used the URL tag to provide a link and named the link. Is there some more information needed to get them to work properly?
Indel B Travel Box Portable Fridge this url link tag works.
[youtube=http://www.youtube.com/watch?v=ubn0sHW4jOk&feature=share&list=UUL0YMA_YmkkAmhhLtNQ3zig]Indel B Travel Box Portable Fridge[/youtube] does not work. This attempt was like using the url tag inserting the web address inside the first bracket with a = in front of the address.
[youtube]http://www.youtube.com/watch?v=ubn0sHW4jOk&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube] nor does this where I copied the web address from the title bar.
[youtube]http://www.youtube.com/watch?v=ubn0sHW4jOk&feature=share&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube]
Getting closer? This time I inserted UUL0YMA_YmkkAmhhLtNQ3zig in the space between the and all I see is a big white Youtube sized box.
[youtube][/youtube]
What is the secret (to get the right movie id to insert)? :thinking:
I tried the movie id from the youtube "share" http://www.youtube.com/watch?v=ubn0sHW4 ... hhLtNQ3zig
[youtube]http://www.youtube.com/watch?v=ubn0sHW4jOk&feature=share&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube] NO WORKY :thumbdown:
Moved on to a teardrop Youtube:
[youtube]http://www.youtube.com/watch?v=74Lm7dAx15M[/youtube] Failed to work.
Success!
Stripped this long address http://www.youtube.com/watch?v=74Lm7dAx15M down to 74Lm7dAx15M and that worked (between the square brackets)!
Steve - SLO, CA
Esteban
Images: 15
Postby mgb4tim » Thu Oct 17, 2013 2:18 pm
just use the youtube ID (74Lm7dAx15M) between the [youtube][/youtube] tags.
Looks like:
Code: Select all
[youtube]74Lm7dAx15M[/youtube]
mgb4tim
Postby mikeschn » Thu Oct 17, 2013 3:50 pm
What Tim said! :thumbsup:
Postby Esteban » Thu Oct 17, 2013 5:47 pm
Trying again with a longer web address:
[youtube]http://www.youtube.com/watch?v=ubn0sHW4jOk&feature=share&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube] didn't work
[youtube]ubn0sHW4jOk&feature=share&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube] didn't work
[youtube]share&list=UUL0YMA_YmkkAmhhLtNQ3zig[/youtube] didn't work
didn't work - though a youtube sized box shows. Inserted( UUL0YMA_YmkkAmhhLtNQ3zig ) between the ] and [ tags
[youtube]ubn0sHW4jOk&feature=share&list[/youtube] didn't work
some youtube addresses are long with multiple = in them so it's hard to decipher which part is the right part to insert between youtube tags. :?
Steve - SLO, CA
Esteban
Images: 15
Postby mikeschn » Thu Oct 17, 2013 6:07 pm
In the first link you showed up there... you only want the part between the = and the &
i.e. ubn0sHW4jOk
everything else is feature lists and share lists, which has nothing to do with the id of the movie!
Postby Esteban » Thu Oct 17, 2013 6:21 pm
Thank you Mike, I would never have guessed that's the way to do that one. BTW I've added TouTubes to the new Skinning Secrets sub forum. Thank you for making it happen. :applause: :applause: :applause: :applause:
Steve - SLO, CA
Esteban
Images: 15
Return to Threads about the forum!
