Air conditioner mounting ideas
Re: Air conditioner mounting ideas
Postby Shadow Catcher » Tue Oct 15, 2013 3:51 pm
I have met a number of those that did the one duct and they made the same 'cold and wet' comment.
Postby oakinteriors1 » Tue Oct 15, 2013 6:34 pm
Ready to do something a little different than seen on here......
This will slide to the center and meet with ducts....probably use some closed cell foam type gasket configuration...
oakinteriors1
Postby steve cowan » Tue Oct 15, 2013 8:46 pm
oakinteriors1 wrote:Ready to do something a little different than seen on here......
Now,that is definately thinking outside the box!
steve cowan
Images: 207
Postby kd5edj63 » Wed Oct 16, 2013 8:54 am
dcefinately creative
kd5edj63
Postby citylights » Sat Oct 19, 2013 8:28 pm
I finally got mine in. Happy with it now. It may look like a wart of the front of my tear, but I like it!
citylights
Postby Todah Tear » Sat Oct 19, 2013 9:20 pm
Todah
Todah Tear
Images: 282
Postby kd5edj63 » Sat Oct 19, 2013 10:16 pm
Thank you, gentlemen. The wart looks fine. I see much craftsmanship in that "wart"
kd5edj63
Postby citylights » Sat Oct 19, 2013 10:28 pm
Todah Tear wrote:Image
I came really close to doing mine like this. Inside it would sit in a cabinet. Open hatch, slide out on drawer slides, use it, done slide in, close hatch. I would not have had the outside braces though.
In the end, I couldn't give up the inside cabinet space. I put it above my bed headboard in a space not being used by anything else. This is what mine looks like inside before I finished it. All painted and trimmed now.
citylights
Postby oakinteriors1 » Sat Nov 09, 2013 7:30 pm
Up into the galley from underneath..
And into the cabinet, the return air duct is on the bottom..
More later...
oakinteriors1
Postby Tucguy » Sun Nov 10, 2013 12:41 pm
I believe that a close look at the optional air conditioning on the Camp Inn trailers may add another idea to this. Their installation is virtually invisible on the outside of the tear (only exterior vent is visible). It does take up some storage space in the center of your over bed cabinet/galley cabinet though. It is worth a look see. The air conditioner is usable with the hatch closed and locked. They (Camp Inn) may use a metal liner or coating to protect the wood at the exhaust end of the air conditioner and to collect the water to a drain line to the bottom of the trailer. Very neat installation. Pull out AC unit from front in cabin for servicing.
Tucguy
Images: 53
