E-mail: [email protected]
530-242-6452
10:30 a.m. to 4:30 p.m., Mon. - Sat., no Sunday calls, please !
Esteban wrote:Glass is very thin if you use 4 or 6 oz. fabric. So thin it's lmost invisible. You can feather it out with fillers or a "bondo" type of filler...which should be up you alley. I suppose you could take a belt sander to the joint to sand a little wood away and then fill it with epoxy and tape...kind of like the indented edges of drywall. Once filled and painted it will not show.
I found a door making video I posted earlier I'll send you soon.
Ah, here it is He uses solid plywood and a piano hinge with his own way of water proofing it...with a bicycle inner tube.
wyldesyde007 wrote:This video was an awesome share! I have been considering continuous hinges for my build and this answered my waterproofing questions
