Winterizing your Foamie' ...
Re: Winterizing your Foamie' ...
Postby Lonewolf42301 » Thu Oct 24, 2013 9:01 am
I have never used the spray bomb stuff, only the epoxy by ppg- 40yrs in autobody repair.... zinc chromate primer best invention since gravy.... :D and since you are close to ocean there is salt in the air.....
Lonewolf42301
Postby Lonewolf42301 » Thu Oct 24, 2013 9:04 am
Lonewolf42301 wrote:I have never used the spray bomb stuff, only the epoxy by ppg- 40yrs in autobody repair.... zinc chromate primer best invention since gravy.... :D and since you are close to ocean there is salt in the air.....
Well, I take that back, weld-thur primer is zinc chromate and used tons of that.
Lonewolf42301
Postby hugh » Thu Oct 24, 2013 9:52 am
When my friend made a set of aluminium fenders I went down to Home Depot, ours has a fairly large nut and bolt section. They sell aluminum screws, so no galvanic corrosion. I thought they would be soft and strip easily so was careful installing them, no problem so far and they are holding up well.
hugh
Images: 11
Postby GPW » Thu Oct 24, 2013 3:04 pm
Hugh, tha’t’s Good to know ..... we haven’t tried Al screws in many years .... :thinking:
