lrrowe wrote:The Wago connectors look neat. I have never seen them before. I am going to order some to see how well they work for me. Thank you for the lead.
Bob
OverTheTopCargoTrailer wrote:I thought you guys have all SWORN on the holly trailer building bible to only use 105 deg c stranded wire![]()
These only work with solid wire of 12-14 AWG![]()
capt4903 wrote:Wago's are fine and dandy for the residential trade who are all about slamming out cookie cutter homes in the shortest time possible...., but in the commercial environment we always twist the wires and use wire nuts...also wires are wrapped around the screws for full contact....if there was a chance of vibration, I always wrapped a few layers of tape around the nut....my main point is, with a "push in" type connection there is only a very small contact area between the wire surface and the tab in the Wago or "back stap" receptacles....that leads to resistance, which leads to over heating of the joint and eventually failure....replaced a lot of the cheap box store recepts for friends which have overheated and failed.....been in the electrical trade since 1998 as an I.B.E.W. trained master electrician.....I cringe when I see some of the photos posted on this website....
just my opinion.....
p.s. almost all the r.v.'s built are wired with romex...just use bushings when it passes through metal studs......
