OverTheTopCargoTrailer 7 x 16
Re: OverTheTopCargoTrailer 7 x 16
Postby Prem » Sun Nov 03, 2013 11:16 am
Jerry,
You'll make cargo trailer sales explode nationwide if you do THAT! Our forum will be buried with 10,000 newbies asking questions about how to install windows and which generator to buy! :o
:lol:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby OverTheTopCargoTrailer » Sun Nov 03, 2013 12:04 pm
Prem
Then you will have to show me how to put a link in the video - so they all end up here on the forum :lol: :lol: :lol:
Next year I wanna see more Halloween decorated trailers here on the forum,
i'm gonna add more lights & a fog machine
Nobody of the 100's of people who walked by were able to guess I had solar panels under cover :lol: :lol:
Now some were saying that the truck might hit the tool box while turning :thinking: :thinking: but I can tell you for a fact that I was able
to easily make 90 deg turns, even extra wide 180 deg U TURNS, turning my steering wheel up to 270 degrees and still had a few inches of clearance left over.
the tool box is full size truck tool box
:FNP :FNP :FNP :FNP :FNP :FNP :FNP
Help my Trailer is full of RATS !!!
Postby Prem » Sun Nov 03, 2013 12:45 pm
:R Thanksgiving theme time now! Can you make it look like a turkey? :lol:
My goal...
Prem
Images: 144
Postby OverTheTopCargoTrailer » Mon Nov 04, 2013 10:09 am
Prem
Send me some ideas for the turkey design.....
to they have a horn that goes gobble ....gobble....???
not sure this would work....but sounds great
http://www.camoent.com/autogobble/
http://turkeycallcarhorns.com/sounds/turkey.mp3
http://www.noveltycarhorns.com/sounds/dog_barking.wav
http://www.noveltycarhorns.com/animal-sounds-car-horns-c-8.html
I did go and get blinking X Mas LED lights at Target only $12 for 20 ft
Postby lrrowe » Mon Nov 04, 2013 10:58 am
Boy could I use the "Bad Dog" barking one to use when all the neighbor's doors annoy us.
Bob
lrrowe
Images: 439
Postby Prem » Mon Nov 04, 2013 11:01 am
Jerry,
:( For my trailer I only have soft plastic, red and green, saguaro cactus lights.
I guess the message of those is: "Real RVers spend all the holidays in southern Arizona."
:lol:
My goal...
Prem
Images: 144
Postby tnriverluver » Mon Nov 04, 2013 5:34 pm
Had mine decorated with skulls and ghost
tnriverluver
Postby OverTheTopCargoTrailer » Sat Nov 16, 2013 9:37 am
Right now it's 41 deg F outside, 64 deg F inside - without the 32" door insulation installed,
Also the rear cargo door is cracked open. I'm USING ZERO HEAT !!
Just 1 person inside.
I'm pretty sure when loaded and finished I will be able to get PLUS 30 Deg F with ZERO HEAT !! :D :D
:D :D :D :D :D
Also so far, knock on wood I'm not having a condensation problem :thumbsup: :thumbsup:
Postby OverTheTopCargoTrailer » Wed Nov 27, 2013 11:33 am
Thank you Bob For the link.....
My head has swollen to double its size already
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
:thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
CarMate Trailers now named trailer of the year for 2014
Postby OverTheTopCargoTrailer » Wed Dec 04, 2013 11:14 am
Its finally winter & freezing cold outside - but still 59 inside OTTCT with ZERO Heat
32" door still needs insulation
:goodmorning: :goodmorning: :goodmorning: :goodmorning: :goodmorning: :goodmorning: :goodmorning: :goodmorning:
the red clock is off by 1 hour , its really 7:35 am
photo 1.JPG (118.35 KiB) Viewed 2658 times
:thumbsup: :lol: :thumbsup: :lol: :thumbsup: :lol: :thumbsup: :lol: :thumbsup: :lol: :thumbsup:
photo 2.PNG (208.87 KiB) Viewed 2658 times
Can you see the frost on the crack house - ?
both have frost inside - no heat source
photo 3.JPG (112.11 KiB) Viewed 2658 times
Postby OverTheTopCargoTrailer » Mon Dec 16, 2013 3:52 pm
Ok here it is, for those of you who like to do winter camping & not have Niagara falls CONDENSATION drip on your head,
this method works as well as spray foam. It may also work in vans as walls are irregular
This set up works quite well with almost zero condensation.
the top diamond plate is of course the trailer roof.
the left side is a wood stud that runs under the metal stud "not shown"
I'm using R-19 Denim insulation - it really only expands to 3.5"
below i'm using 3/4" blue board mainly to compress the Denim - so there is no air space between metal roof.
the bottom layer is 1/4" paneling
Now most of you will LAUGH, because loosing even a single inch is blasphemy in your build
but since I have expensive solar and other electronic stuff on board...
one little drop is all it takes for a nice fire or a short.
photo 1-2.JPG (155.35 KiB) Viewed 2495 times
Postby lrrowe » Mon Dec 16, 2013 4:52 pm
Since I will most likely never camp in the western and southwester regions where the temperature can change so much between day and night, I will probably insulate to what ever the air spaces allowed in the sides and ceilings. I will spend the time and energy to learn more about the condensation issue so as not to allow mold or rot to exist in my CT. My camping when my wife is with me will probably be in the later spring to late summer in the East and South. The other times in cold weather will be me or a fellow fisherman or hunter during the colder weather. So for the cold weather insulation will be very much appreciated. But the maximum amount I "could" get if I accepted lesser interior dimensions is not that important to me. I am almost 70 now and still camp in makeshift camps like this picture shows:
This pic shows the 10 x 20 Carport we set up.
115314
This pic is of an 8 x 8 Canopy setup in the Carpot with plastic sheet and tarp draped over it. So in effect, I had a tent within a tent. It held the heat from a Mr. Buddy and a heater on top of a 20 gal. propane tank pretty well while running. At night there was no heat provided.
115315
I was very cosy in it and quite warm at night in 25 degree temps. Sponge baths were also not that bad (with the heaters on of course).
So you can see my needs will be less then the others.
Now I have until the end of this month to order my trailer before a price increase is in effective. I am down to a Car Mate 6 x12 Advantage and or a Car Mate Custom Cargo, 6 x 14, both Single Axles. I am struggling with the price differences now and the space lost going to the V-Nose Advantage unit.
So as not to take over this tread, in a few days I will post a new thread dedicated to this build and there I will be showing my ideas about condensation and my solutions, looking for comments and ideas.
Bob
lrrowe
Images: 439
Postby wtcreaux » Wed Dec 25, 2013 11:40 am
lrrowe wrote: Now I have until the end of this month to order my trailer before a price increase is in effective. I am down to a Car Mate 6 x12 Advantage and or a Car Mate Custom Cargo, 6 x 14, both Single Axles. I am struggling with the price differences now and the space lost going to the V-Nose Advantage unit.
I'm confused......How do you lose space by using a V-nose?? :thinking:
wtcreaux
Images: 211
Postby piperpilot3tk » Wed Dec 25, 2013 12:01 pm
Some manufacturers include the V nose in the advertised length, others do not and only advertise the length from the aft of the V nose where the floor is full width. Also there are different dimensions of V nose areas, most are three feel long, but some are two, others are four plus feet long and go all the way to the coupler.
piperpilot3tk
Images: 29
Postby wtcreaux » Wed Dec 25, 2013 12:24 pm
Thanks piper, that makes sense.....the ones I've looked at are "A x B" + "the V".......highlights the need to make sure comparing apples to apples.......
wtcreaux
Images: 211
