Esteban wrote:Reviving a very old thread. Clamshell vent covers, of the right size, functionally similar to these: Perko Midget Clam Shell Vent Chrome-Plated Brass would work to keep rain out and let air in.
Mike's cad drawing is close to how Spenser's cookie tin heater was built. The candles are much shorter than Mike shows. Long burning Tea Light candles like these from Target would work 7 Hour Tea Light Candles - White (100 Count) Robert used one or more long burning candles in the lowest tin box with an air inlet. Heated air flowed through the other boxes radiating heat into the sleeping cabin and then was exhausted to the outside from the last box on top. The cookie tin covers are held in place with a bolt through the center of the cover and a wing nut. We never got a photo of the heater to share.
The parts to build the heater are low cost. New cookie tins (can) come with cookies! The holidays are coming up so they may be more readily available.
Google images of square cookie tins
cookietins.com sells them in small quantities.
mikeschn wrote:Esteban,
So if I understand this correctly, Robert placed all his candles in the first box? Whether it was 1 candle, 2 candles, or 6 candles? And the four cookie tins is to capture more of the heat before it exhausts?
I wonder if the 2" holes are too big. Maybe 1 1/4" holes? And I wonder if the handibacker in between the bottom row of tins and the top row of tins is hurting the heat output, or helping it?
Mike...Esteban wrote:Reviving a very old thread. Clamshell vent covers, of the right size, functionally similar to these: Perko Midget Clam Shell Vent Chrome-Plated Brass would work to keep rain out and let air in.
I added start8 and now it works just like window 7. Do yourself a favor and get start8
jstrubberg wrote:In a teardrop, I would go with a 12v heated blanket laid underneath me on top of the mattress. Running that for an hour or so would warm the mattress and cabin up. No flames, no exhaust, minimal battery draw.
