mikeschn wrote:Good point. Both pods have a 1/4" gap under the door, and 3 holes up high on the opposite end.
I looked at my smoker to get the idea of the size and qty of holes I need, and made them about the same. When my smoker is running, the smoke just pours out of those holes... I suspect I am getting enough air through there..
Okay, I just found out that I am getting too much air flow through the pod. I was told that as the temp approaches freezing too much body heat is going out those holes.
I suggested plugging a couple of the holes...
But I had another idea and wanted to run it past you guys.
Since there is a 1/4" gap under the door where the air comes in, can I just put 3 holes in the wall above the door? (and block the holes on the opposite side)? This way instead of the going all the way across the pod, it comes in and goes out on the same wall, leaving most of the pod air warm.
Is this a reasonable idea?
