Inside door skin?
Important Information and Stickies...
(Threads with essential information about building teardrops)
Inside door skin?
Postby citylights » Sun Nov 17, 2013 7:12 pm
How do you skin the inside of a door? (Mine need to be done)
I was going to cover it in 1/2 inch foam, then fake leather. Then install a curtain rod and curtain.
Ant better ideas?
Here is a couple pictures of the inside of my door.
citylights
Re: Inside door skin?
Postby mikeschn » Sun Nov 17, 2013 7:51 pm
What's the rest of your interior finished with?
Typically I finished the insides of the doors with a few coats of spar urethane.
Yours look a little rough. You might want to knock the edges off with a sanding block, and then coat it with some polyester resin. That'll give it a nice thick, smooth surface.
Postby citylights » Sun Nov 17, 2013 9:13 pm
mikeschn wrote:What's the rest of your interior finished with?
I used ugly 3/4 pine plywood for my tear sides. Everything needs a skin.
citylights
Postby CowboyKell » Mon Nov 18, 2013 12:35 pm
Mine is in process but I am using a very cheap luan from Lowe's. Red Oak, looks pretty good for the price.
CowboyKell
Images: 5
Return to Essential Information about building teardrops
