Should we talk about homeless shelters on this forum?
A place to talk about homeless shelters, design and construction. (No politics)
Re: Should we talk about homeless shelters on this forum?
Postby Verna » Mon Nov 18, 2013 7:03 pm
Mike, I guess I should have also said a solid exterior. Sorry about that misunderstanding.
There are a lot of crimes within the homeless community that a solid sleeping pod would help prevent. I liked the insulation you put inside the first pod you delivered, but the solid OSB exterior was the best.
Verna
Indianapolis, IN
Verna
Images: 49
Postby grantstew8 » Mon Nov 18, 2013 7:07 pm
Sips panels are 1200 (4') wide x 2400 (8') and 4800(16') and various thicknesses.
By turning these into components by cutting a panel in half vertically and/ or horizontally allows almost any shape to be designed and simply erected. A flat pack can be created and with basic tools and skills can be erected quickly.
Okay it's not as cheap as a tent.
I've spent years kicking designs around. The critical dimension is the roof span max 4800 16' in any one direction. From there the design is limited by the costs of doors and windows.
I've an office 12' x 30' that is warmed using a 2kw heater with the thermostat set at 1 the lowest setting When the sun shines it's toasty and I'm talking about mid winter in Scotland.
grantstew8
Images: 77
Postby mikeschn » Mon Nov 18, 2013 7:26 pm
Verna wrote:Mike, I guess I should have also said a solid exterior. Sorry about that misunderstanding.
Verna,
#1 used 5mm moisture resistant luan throughout. I was trying to make it light. Then afterwords I added insulation.
#2 used 7/16 OSB for the front and rear, 1/4" OSB for the sides, and 5mm moisture resistant luan for the roof. The insulation was captured in between the spars and the skins.
The OSB pod was quite a bit heavier to move. But I suppose they are both wind resistant to a point... And they are both solid exterior. So you like the OSB better than the luan?
Postby Verna » Mon Nov 18, 2013 7:36 pm
Mike, either one is good. I guess in my haste to make sure you understood I wasn't referring to a foamie, I just remembered the OSB on the door. As long as there is insulation in the pods, it 's a great thing r94 all seasons. In the Habitat for Humanity builds that I have helped on, they used OSB because it was less expensive than plywood. So, whichever one you use is fine-- both Luan and OSB are used in stick built homes.
Verna
Indianapolis, IN
Verna
Images: 49
Postby Miriam C. » Tue Nov 19, 2013 12:26 pm
:thinking: Great idea. Doesn't matter what your political or social leanings are, shelters are needed for lots of reasons.
We had a lot of experience with sheltering people here, and most of our churches survived so it was not an extreme issue like in the Philippines. I just wonder if things had been different and our damage more wide spread.....
I will include a utube site I happened across where a Ti-pee was made of coroplast. Folded and worked great but would need tie-downs.
Postby Prem » Wed Nov 20, 2013 2:08 pm
Mike asked:
Should we talk about homeless shelters on this forum?...Your thoughts please.
Here's another vote for Yes. :thumbsup: ...cuz when I leave the home behind, hit the road and camp out, I'm technically homeless. I think that the homeless shelter I am currently towing is pretty good, but I am always looking for a better homeless shelter.
:thinking:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby darrellbeck » Fri Nov 22, 2013 10:47 am
Oldragbaggers wrote:I think this could be appropriate here, as a section of it's own, since it involves the construction of small shelters. Ideas that get put into play with these shelters may have a lot of crossover and end up being ideas that people can also use in the construction of their teardrops and tiny travel trailers. How can more good construction ideas be a bad thing??
That being said.....I would also add to the concerns voiced about keeping the politics out of it. I am also on a Cruisers Forum for boaters and one of the ugliest threads I have ever seen started out as a thread about boats being a viable alternative housing option for homeless people. Folks who had been friends on the forum for years ended up fighting like cats and dogs. Administrators had to lock out that thread, and several others that have come up on the topic since. (It seems like there is always someone who wants to keep the fight going and will just go start another thread about it.) It has become a real bone of contention that, once started, has been hard to stop.
It is obvious that this forum is no longer strictly about teardrops and tiny travel trailers anymore anyway, and for some people almost has a Facebook aspect to it where they want to post all their life status updates all the time. In some ways I get that because a lot of us have met other members camping and have become friends, although I do think that if you have come here looking for INFORMATION sometimes wading through all that stuff can be daunting. Personally, I have been here long enough to know how to pick through the posts. I think one thing that might help that for those less initiated to the forum would be to tighten up the definition of the "General Discussion" section so that it is general discussion of teardrops and tiny travel trailers only, and have all the Facebook type stuff go in the off topic section.
I have to agree with this 100%. I have seen too many friendships ruined, clubs broken up, and enemies made over politics and religion. This subject needs to be on a single topic thread if it is on this site at all. I do believe, however, that some of the ideas the members of T&TTT have had would also be valuable in the design of these little shelters. Because of this, and the obvious need to do something about the homeless problem, I would vote (while no vote was asked for) for a separate, heavily monitored, thread.
darrellbeck
Images: 24
Postby Prem » Fri Nov 22, 2013 11:58 am
Totally agree with that. Well said too. :thumbsup:
My goal...
Prem
Images: 144
Postby grantstew8 » Fri Nov 22, 2013 5:21 pm
This is the first forum I've joined and really got a lot from and hopefully contributed something too.
I found this site because it specialised in teardrops tiny trailer. This new thread/discussion although related to building small spaces, is not related to tnttt
Although heart breaking to see homelessness of any description, it may be worth considering having a separate homeless house pod forum. Our motivation, skills and a desires, may take a specialised forum off in another direction albeit kindhearted and well intentioned.
It is likely that through search engines more members will join based on the homeless section rather than a group of tnttt builders kicking ideas around. (Good ideas)
I'd rather see a completely separate forum than including homelessness on tnttt. The forum will risk becoming confusing and losing focus. The focus on tnttt is its essence and appeal.
$0.02.
grantstew8
Images: 77
Postby aggie79 » Mon Nov 25, 2013 5:10 pm
I say give it a go here, but if the topic takes off, it may warrant a new site.
Postby rebapuck » Mon Jun 16, 2014 11:00 pm
If it's not done here, then where? What could be more in line with a sleeping pod than a teardrop? People here are smart, creative and generous with their ideas.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby vzepol » Thu Dec 01, 2016 2:32 pm
I am new to this forum. Please excuse my late contribution.
I have been noodling around some ideas on mobile sleeping pods. I am hoping that this is someplace where we can come up with something that might help. I drive past a couple of homeless encampments every day. I have to say it breaks my heart.
vzepol
Postby OliverJohn2030 » Thu Jul 14, 2022 3:09 am
I have often thought I could live in the trailer, if I had to. I'd say add it in.
OliverJohn2030
Postby TCJ » Fri Jul 15, 2022 9:16 pm
Verna wrote:Yes, I do agree with Dale that we do need to keep politics and reasons for homelessness out of the topic.
And yet Dale's signature is pure politics, just saying.
TCJ
Postby friz » Sat Jul 16, 2022 12:38 am
It's great in theory. We have multiple resources for homeless in our little town. The issue has been for us, when you place rules on your shelter site, the homeless go back under the bridge. We do have a soup kitchen so at least they can get a hot meal once a day.
Sent from my SM-S906U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Return to Homeless Shelter Design & Construction
