by Esteban » Tue Nov 19, 2013 11:18 am
I woke up thinking about conduction, convection and radiation. Three ways heat is transferred.
The thoughts lead me to wonder how to make the cookie box heater work well/best.
Conduction. To reduce conducting heat through the wall of your teardrop you need to reduce direct contact of the back of the cookie tin heaters to the wall of your camper. Maybe by having a standoff between the back of the cookie tins and the hardibacker board that is up against the cabin side wall to create a small (insulating) air gap. The standoff might be small pieces of the hardibacker. Insulation within the wall behind the heater will reduce heat conduction to the outside too (conservation).
Convection. Heat convection is what you want to happen inside the cookie tins in a controlled way. You control the convection by using multiple cookie boxes, by the placement/use of the fresh air inlet and exhaust air outlet, and by the air connections (pipes) between boxes. Baffles inside the tins might help too.
By using standoffs, that might be about a quarter inch, behind the cookie tins to provide an air gap between the back of the tins and the hardibacker I hope it would create a convection current behind the heater. Then heat from the back of the heater can be conserved (less conduction to the colder outside) with a little more warm/hot cabin air convection movement happening.
Radiation. The cookie tins are meant to safely radiate the heat from the candles to the cabin interior. The more surface of the cookie tins that is exposed to the cabin air the more potential for radiation (up to some optimal point).
Robert had "pipes" between the cookie tins that he "welded" airtight to the tins with JBweld. This morning I wondered what you might use for the pipes. I looked inside my kitchen cupboard at cans of food. The narrowest cans I have are 2.5" wide. Maybe too big? Maybe something smaller like part of a tomato paste can could be about the right size to become part of a pipe between cookie tins.
My thoughts may be (are) a little jumbled. Hope they make some sense and add to the discussion.
Steve - SLO, CA
