the Hotmail Heater and water heater
Re: the "Hotmail Heater"
Postby rowerwet » Thu Apr 12, 2012 10:00 am
latest sketchup design with a hot water tank for the galley using the "waste" heat to heat the water. 90621
90620
90619
rowerwet
Images: 521
Re: the Hotmail Heater and water heater
Postby mikeschn » Wed Nov 13, 2013 8:17 am
This looks like an interesting heater. So you've already got the parts in the garage. Can you build it so we can see it in action?! ;)
Can we see a picture of the parts? I'm curious to see the actual sizes of the parts relative to each other, and the size of your kerosene lantern.
And I'm also curious how much you spent for your mailbox and your lantern.
Postby rowerwet » Sat Nov 16, 2013 2:04 pm
I got the lantern at wallyworld and other cheapskate places
114340
for something like $10 I think http://www.walmart.com/ip/FloraSense-Hu ... k/16783700 we use citronella oil in the lamps to keep the bugs down
114341
the mailbox is a standard rural one, I bought an aluminum one to help the heat transfer. cost $20 or so. http://www.homedepot.com/p/Gibraltar-Ma ... oe_xnBjvac
114342
the lantern fits in the mailbox just fine. After a while of letting the idea roll around in my head, I see my self just mounting the mailbox inside the trailer somewhere. Instead of putting it in a jumbo size rural mailbox or building a plywood box around it. Both of those ideas would need to be mounted in the tounge box or galley, with a hole in the bottom of the trailer to insert the lantern.
This would also make it easier to control if you wanted a higher flame, or to shut it off.
rowerwet
Images: 521
Postby rowerwet » Sat Nov 16, 2013 7:17 pm
the opposing thought, the lanterns seem to leak from the bottom seam (what I get for buying cheapo ones) the oil would drip into the tear off of the mailbox door.
the leak seems to be only if stored for weeks, normal use during camping, with the oil being filled and used each night, never left a ring on anything the lanterns were left on.
kerosene fumes are also not healthy to breath, putting the mailbox into a plywood box that had a fan blowing into it from the tear would cause any air leaks would be into the mailbox and then out the exhaust
rowerwet
Images: 521
Postby rowerwet » Sun Nov 17, 2013 1:29 pm
brass, sink drain tailpiece I found to act as the intake and exhaust vents.
114357
measuring the height the upper drain tube needs to be, it should be aimed at the normal height of the flame top, to check for a smokey burn, as this will soot up the glass, making it useless for camp illumnation
114356
there is a "hair catcher" inside the drain tube, not sure if it can be knocked out or not, I don't want to ruin the tube, and it won't really stop enough airflow to be a problem.
114358
since a mailbox is only meant to be water proof when horizontal, the bottom holes will need to be sealed with a plank, this would also be the area to mount the box to the wall of the tear.
114359
rowerwet
Images: 521
Postby mikeschn » Sun Nov 17, 2013 4:03 pm
Rowerwet,
Keep the information coming.
For the bottom plank, can you use a piece of tin from one of the big box stores? Maybe pop rivet it on?
Postby Wild Idaho » Wed Nov 20, 2013 10:35 pm
Rowerwet,
You've really piqued my interest in this. All the camping I do in Idaho is off the grid up in the mountains. I'm hoping a heater like this could take the chill off. I'll be keeping an eye on this.
Jeff
Wild Idaho
Images: 97
Postby rowerwet » Thu Nov 21, 2013 7:24 am
thanks for the interest, this is much more an idea and theory, for a proven design that is being refined check this thread viewtopic.php?f=2&t=18902
rowerwet
Images: 521
Users browsing this forum: Bing [Bot] and 11 guests
