Colours for painting the inside of TD
Postby Kody » Thu Nov 21, 2013 7:10 am
We are thinking that we might paint the inside of the TD with a high quality paint like marine grade paint. I could use a good interior house paint but that's not the problem. Does anyone have any photos of the interior of their TD that was painted with a colour? I would like to paint the interior with a clear polyurathane but by the time I sand the ply to a smooth surface, the top veneer will be extremely thin or non existant. The surface of the ply has "roughed up" somewhat because of the extreme change in the humidity. Are there any photos available to have a bo-peep at to see how your pride and joy has turned out.
Kody :thinking:
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Re: Colours for painting the inside of TD
Postby 48Rob » Thu Nov 21, 2013 7:45 am
Carpet on the ceiling, oil based enamel on the walls.
Rob
48Rob
Postby RandyG » Thu Nov 21, 2013 12:01 pm
I just primed with Bullseye primer/sealer and painted with interior paint. 112388 It's still in work though.
Randy
RandyG
Images: 115
Postby absolutsnwbrdr » Thu Nov 21, 2013 12:13 pm
I primed the inside with Kilz Premium, and then used a "kitchen & bath" paint from Lowes. I think "barefoot beach" was the color.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby GPW » Fri Nov 22, 2013 6:19 am
Primed the inside of our trailer with Glidden Gripper, then mixed up all our left over paint to make a nice greenish gray ... Thrifty !!! :D
FStable 2.JPG (237.2 KiB) Viewed 1005 times
Postby Irmo Atomics » Fri Nov 22, 2013 8:07 am
I painted mine a homemade brew that turned out to be a sea-foam green, a light, light blue ceiling and bright yellow trim and accents.
102964
97587
Bob
Irmo Atomics
Images: 64
Postby working on it » Fri Nov 22, 2013 8:33 pm
Outside: grey, silver, with black trim; inside: grey, silver, with black trim...whoops, I sense a pattern here!114136108389
173193172890148599
working on it
Images: 457
Postby Vedette » Sat Nov 23, 2013 11:19 am
It does not matter what you paint it with.....just keep it light.
Teardrops a close quartered enough. :R
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby working on it » Sat Nov 23, 2013 12:31 pm
Vedette wrote:It does not matter what you paint it with.....just keep it light.
Good Roads
Brian & Sandi
In defense of my small and (mostly dark) interior (same as exterior) paint choices: after dark, with the main LED lighting on (110vac IKEA strip lights) 107294 or the overhead 12vdc globe lights on (4 in a row)106342 the trailer is too bright. The silver-painted (reflective) ceiling is just for that light amplification effect. I use a group of 4 RGB-LED puck lights (also 110vac from IKEA) mounted forward on (vertical surfaces) for less light,104352102807 or even dialed to different mood lighting hues for drowsing. 104353 At daybreak, the curtains (black lined, but not opaque) 108391 allow enough lighting in from the two windows. Or draw the curtains back. After all, I built this trailer (ostensibly) as an "expedition base" for my wife's hobby (but in actuality, as my "man-cave" on wheels). Either purpose dictates the choice of a darker set of colors. It's also a bunker! 109058114373 I must be a morlock at heart.
173193172890148599
working on it
Images: 457
Postby les45 » Sat Nov 23, 2013 5:18 pm
+1 on what vedette said: keep it light and it will feel a lot roomier. Mine is light green walls with white ceiling, all with Zinsser primer and acrylic latex house paint with no moisture problems.
les45
Images: 605
Postby Kody » Sun Nov 24, 2013 2:50 am
Hi guys
These photos are all looking great. Many thanks for posting them. Do you have any more to show us please?
Kody :thumbsup: :applause:
Kody
Images: 22
Postby Woodbutcher » Sun Nov 24, 2013 9:45 am
The only one I painted was done in a pale green, (seafoam) . Sorry this is the best picture I can find.
Woodbutcher
Postby Junkboy999 » Sun Nov 24, 2013 6:12 pm
another +2 for keeping it light. Mine is painted Dark green. It looks nice in contrast to the stained pine cabinets but is too dark. Once a mosquito gets in there and goes anywhere near the walls, it disappears and you can’t swat it. It will be re painted a light green or pale blue next year.
PS dont try to sand the ply smooth use a filler if you are going to paint plywood. Even super thick primer and sanded down untill you just start to see the wood. Then apply more printer as a filler and last paint. easier to do in the TD is not assembled.
Junkboy999
Images: 52
Postby S. Heisley » Sun Nov 24, 2013 6:56 pm
I tried to make my interior look like I was in a fenced garden. The lower walls are wood tone and the floor is tan with scattered replica brown leaves. Above the wood tone "fence", I used a sky blue paint. I picked up a paint sampler sheet and then watched the sky for a shade of blue that I liked a lot and then matched the paint samples to that. It worked out okay. I was going to paint clouds in the "sky" but, in the end, thought it might be too much. I still might add the clouds someday, though....
Postby Ron Dickey » Mon Nov 25, 2013 2:52 am
I usually paint it white so I have more light with only 2 windows in the Boxkite. disadvantage I pull with a car and tie thing in side the cabin and after a rough ride there are scratches all over the walls.
one way to make is seam bigger inside is to make one wall darker then the rest it makes it feel larger.
You can also glue on fancy decorative sheets.
here are some examples
http://www.spoonflower.com/tags/camping
and there are many many other designs.
Ron
173882......173887
Ron Dickey
Images: 787
