inside galley
inside galley
Postby thorr » Thu Nov 21, 2013 10:31 pm
does any body know of a td plan or build with an inside galley
thorr
Re: inside galley
Postby jandmz » Fri Nov 22, 2013 5:57 pm
Its a TTT, and not exactly a TD, but the Compact in the design library above has an indoor galley. Most TD designs just don't have the headroom to make an indoor galley usable.
jandmz
Re: inside galley
Postby S. Heisley » Fri Nov 22, 2013 8:57 pm
You pretty much need to buy or build a standy or a ttt with a lifting roof.
Below is a thread that lists the addresses most of the teardrops and tiny trailers with lifting roofs that have been built and displayed on this forum:
www.tnttt.com/viewtopic.php?f=5&t=50969
Not even considering the fact that you can't stand up in a TD, you are supposed to have a 19 inch clearance between a stove burner and the roof for fire safety reasons.
A lot of people put up a shelter around their exterior TD galley, which keeps them warmer and enlarges their living space.
