madjack wrote:Jason, you won't care for my advice but I say cut 'em out and start over, you will only be magnifying problems down the road as you try to build your hatch, and skin and trim the trailer...when we built ours, we cut the spars so that the overall was 47.75(46.25" spars)...this gave us a little wiggle room when instaling the ply substrate and the Al skin...and we were thankful for it when the time came...
JasonTX wrote:I have no clue as to why I have a 48 5/16 and fear this will cause problems when it comes time to build the hatch... but hopefully someone can offer some advice. Thanks in advance.
Miriam C. wrote:Jason,
2 things.
If you are not lining your spars up perfectly (if they slant) they can fit wrong and the result can be longer or shorter. Try measuring up every, however many inches you are spacing on both sides and mark before putting them in.
Secondly, try to cut your spars all at the same time. Put them together by clamp or screws and treat them as one piece of wood..
Is it possible your floor is not square and you are using it as a measure, or your sides have a slight warp in them?
Miriam
