Did you guys see the candle furnace that Paul Elkins came up with? here: http://tnttt.com/viewtopic.php?p=1050017#p1050017
Rainier70 wrote:Interesting thread.
I think if I was doing this, I would go with one box off set from the wall a little. Then I would put a shield or partially open box around it. The shield would keep from getting burns, and would also provide an air path around your burner box for a computer fan to draw more heat off.
At the very least I would experiment with one box first and see how much heat your can get off of it. Easier to problem solve venting and sealing issues on one first.
mikeschn wrote:Did we ever decide what's the best way to handle stratification of heat in something tiny like a teardrop?
mikeschn wrote:KC, Do you think those fin thingies would help with a candle heater?
Esteban wrote:Rainier70 wrote:Interesting thread.
I'm skeptical whether one box would be sufficient. With one box it would have both a fresh air inlet and an exhaust outlet. My concern is that the heat would escape too easily. Inside baffles above the candles might help.
This is a thought experiment. Unlike Mike I am not doing a real test:
In my imagination I'm thinking a three box heater, with 3 vertical boxes, could work. The bottom one, to act as a combustion chamber, for the air inlet and the burning candles. A second (middle) box for heat radiation and to baffle the rising heat. At the top a third box for more heat radiation that has the exhaust to the outside. I wonder if internal baffles in each box might help? I think if the rising hot air has to follow a serpentine path through the boxes more heat might be radiated.
Googled "cookie tin" and found the Container Store has many to choose from. 8-1/8" x 6-3/16" x 2-15/16" cookie tin are rectangular tins that could create a compact cookie tin heater. Using three of them the heater might be about 8-1/8" wide and about 19" tall. I could have used many other sizes instead.
