by Nobody » Mon Nov 18, 2013 10:37 am
No welding required Lauren. The only welding I did on my trailer was the 'perches' for the front stabilizer jacks. The tongue mod was all bolt on, using materials I had on hand (except the 2x2" tongue extension). Somewhere here on the forum I have a post on the procedures I used in the mod. Basically I just bolted a couple of pieces of 2" angle iron longitudinally under the first 2 cross members, removed the 'clunky' HF coupler, flipped the coupler base, ran the tongue extension through the upside down base & between the angle iron, drilled holes for 1/2" automotive grade bolts, bolted it all up, & added a new coupler & safety chains. I think there are pix somewhere in my album.
Oh yeah, when I moved the axle to the rear, I used the 2 steel cross members that fit 'back-to'back' & join the 1800# HF trailer. Those pieces fit exactly inside the side rails of the trailer & provide much greater rigidity for the chassis.The spring assembly is simply a piece of angle iron on which the springs/shackles are mounted, & bolts to the side rails. I just unbolted them, moved them back as far as possible to the next crossmember, squared them to the coupler, drilled a couple of new holes, & bolted 'em up. The wood 2x4 you see in the pic, I used to replace the 2 steel cross members I scavenged for the side rails. Since it is merely to support my floor frame at that location, more strength is not needed...
Harvey -
