Woody wrote:I have seen alot of ways the seal the bottom of a teardrop. Spray undercoating, roofing tar compounds, varnish, epoxy, metal, and fiberglass etc. I think that they are all good ways of protecting the underside of a teardrop. I plan on using on the second teardrop I am building to use fiberglass and epoxy resin process that Steve Fredrick used on his tear. I like the way the process penetrates the the fiber of the wood and plasticizes it as a water proof barrier as he states. It may be alittle more expensive, but, well worth the piece of mind of water damage on the underside at the attach points and frame rail contact areas. It has always been my experience that out of sight out of mind areas, like the underside of anything. That the damage is only noticed after it is to late. Just my opinion
