Window Question
Window Question
Postby Joel S. » Sun Nov 24, 2013 9:07 pm
Newbie converting 6 x 12 Interstate to camper . Question about windows . Having difficulty finding used sliders to fit between the steel ribs . Question, can you install a horizontal slider vertically? Really would not like to cut a rib but can if need be . Thanks for any help. :thinking:
Joel S.
Re: Window Question
Postby PaulS » Sun Nov 24, 2013 9:34 pm
Sliders are made to be installed horizontal the drain holes are put in according to the orientation . Just cut the riband.then you can add some angle iron to the ribs on either side.
PaulS
PaulS
Re: Window Question
Postby Prem » Sun Nov 24, 2013 11:00 pm
I found my vertical sliders on eBay. They fit between the ribs without having to cut anything but the skin.
As previously mentioned, RV windows have drain holes for their proper orientation, so you probably don't want to install a horizontal RV window in a vertical orientation, only to realize later that there's water coming in or that gravity makes them slam shut or open. (Vertical sliders have one or two stops for staying open.)
For what it's worth.
Best wishes. :ok:
My goal...
...is to live in a trailer.
Prem
Images: 144
Re: Window Question
Postby MtnDon » Sun Nov 24, 2013 11:20 pm
Right. RV windows just like home windows are designed to work in one plane only; vertical or horizontal movement.
MtnDon
Images: 24
Re: Window Question
Postby OverTheTopCargoTrailer » Tue Nov 26, 2013 1:20 pm
A Big RV window.JPG (120.29 KiB) Viewed 1032 times
I say GO FOR BROKE !!!!
may as well have the best view in the trailer Park :thumbsup: :thumbsup: :thumbsup:
