Aluminum roof seam question.
Postby inthewoods » Sun Oct 06, 2013 12:06 am
I've found that in my area I am only able to get your typical RV roll aluminum 36" or 49" wide or the seamless roof that is 98" ish wide. It's sold by the SQft. My roof is about 63" wide so I will either have to buy 98 and cut it down with a fair bit of waste or use narrower sizes and put a seam down the centre of the roof from front to back. I prefer the look of the seamless roof but I'm really fighting the cost difference. Metal suppliers here are expensive. About 440$ in aluminum for the 98" wide 0.030 or I'm estimating around the 200$ mark if I put a seam in the roof along the centre line. I've found a guy selling the narrower widths at huge discount.
What do you folks think? Anyone done a long centre seam on the roof? How would I seal such a thing?
Thanks for any advice you can give!!
inthewoods
Images: 25
Re: Aluminum roof seam question.
Postby Irmo Atomics » Sun Oct 06, 2013 5:33 am
I bought 97" long sheets and cut them down to fit the width of my camper. My seam is side to side. You're going to have waste either way you go - if you do put the seam lengthwise, be sure to center it just right or it might look funny.
Bob
Irmo Atomics
Images: 64
Postby prohandyman » Sun Oct 06, 2013 11:39 am
Woods...how far are you away from from Michigan? Frank Bear over at vintage technologies can supply you with a roof cut to your dimensions and quite a few colors. Take a look at this pic...the seam in the roof , between the name decal and drip rail, is where 2 sheets are permanently crimped together for a leakproof seam. You have this seam every 4 ft across the roof and can be exactly your width. I use him exclusively for my roofs if a painted roof is needed. Come with a PVC wrap for protection in shipping. I took a scrap piece, pushed it in a bowl shape, and let it sit for 6 months with water sitting on it, 24/7, for a leak test. Completely dry underneath.
113159
Dan
prohandyman
Images: 785
Postby inthewoods » Mon Oct 07, 2013 1:12 am
That's a really nice seam... I am up in Saskatchewan, Canada and so Michigan is a bit out of reach... 20 hours or so by road and shipping something that far and across the border is likely going to cost and arm and a leg for me. Cost for aluminum varies so much from One RV dealer to another and most of the aluminum is quite thin - 0.024 is really common for me. Sure would be nice if there was a Canadian teardrop supplier for us northern folks. Best I've come up with so far is to order trim parts from the guys at Teardrop fixit shop in Montana and ship it to the nearest border crossing and drive over to pick it up. Ironically it's looking like it will cost about the same including the fuel to do that versus buying RV insert molding from the RV shop 45min from my house. Plus the trim from fixit shop looks so much better IMO. I may try to see about getting aluminum from the US the same way as the trim parts but it might be tough unless anyone knows of a good source for aluminum in the north eastern part of Montana.
inthewoods
Images: 25
Postby Nobody » Mon Oct 07, 2013 9:15 am
Your original post sounds as if you can get the 49" wide aluminum in 'roll' form. If so you can cut it in 63" lengths & make your seams crosswise (each seam over a roof spar). Depending on length of your TD/roof you shouldn't need more than 3 or 4 pieces. Easy to secure & seal & each seam can 'over-lap' in whichever direction will provide correct water down flow without allowing any leakage or water entry into the TD. Lots of builders here have done that. Check my album for pix of example...
Harvey -
Nobody
Images: 342
Postby KCStudly » Mon Oct 07, 2013 3:03 pm
Did you try big rig truck repair shops? You must have one of those within a reasonable distance and they usually stock the large rolls for box trailer repairs. Should be less money than anything with RV associated with it.
Postby aggie79 » Wed Oct 09, 2013 9:32 am
With a 5-foot wide teardrop and 4' x 10' aluminum I had three transverse seams - two on the teardrop and one on the hatch.
At the seams, I overlapped the aluminum. I first installed the bottom layer. Then, on the top layer, I pre-drilled holes for screws that would fasten through the two sheets into the spar. I used a drilling jig made of scrap MDF as a guide for spacing the holes. Then I temporarily fitted the top sheet and drilled holes throught the bottom sheet and into the spares. I peeled back the top layer and added sealant at the overlap of the seams. Then I placed the top sheet back into position and installed temporary screws until the sealant had set. Then I removed the temporary screws, injected sealant into each pilot hole, and installed permanent stainless steel screws.
Here are few pics of the process:
This is a pic of the hurricane hinge getting ready to be installed, but it shows the method and type of syringe I used to inject the sealant into the screw holes.
This is the best picture of the finished seam that I have. Please note that in the picture below, I had not removed the sealant "squeeze out" that happened when I installed the permanent stainless steel screws.
Take care,
Postby inthewoods » Thu Oct 17, 2013 1:44 pm
@Tom. Thanks for the nice photos and details of your build. How much of that 3m sealant /adhesive did you use? I will like use sikaflex 221 which seems to be similar but easy for me to get locally. I just have no idea how much I'd probably need.
inthewoods
Images: 25
Postby aggie79 » Fri Oct 18, 2013 11:28 am
inthewoods wrote:@Tom. Thanks for the nice photos and details of your build. How much of that 3m sealant /adhesive did you use? I will like use sikaflex 221 which seems to be similar but easy for me to get locally. I just have no idea how much I'd probably need.
Sikaflex 221 is a great product and will work fine. I used a bunch of sealant and probably too much. I'm pretty sure Sikaflex will have a brochure that will give you an estimate of linear feet of sealant per tube for a certain bead size.
I believe the 221 is a moisture-cure product like the 3M 4200. If so, make sure you have enough work ready to seal when you open a tube because you probably will not be able to save any remainder for application at a later date.
Postby canada-paul » Fri Nov 22, 2013 10:25 pm
Hi, I got my aluminium from LonePine RV in Airdrie. Im in Calgary. I think they charge $20 foot for 8' wide for roof aluminium. Long story about what happened with mine, but im really pleased with the outcome. Im almost finished building so will be posting pics etc soon.
Paul
canada-paul
Postby 48Rob » Sat Nov 23, 2013 8:21 am
Tom,
Very nice detail work! :thumbsup:
Details take most of the build time, but make all the difference.
Rob
48Rob
Postby crazycyclist » Mon Nov 25, 2013 10:17 am
Check sign companies for larger aluminum sheets.
Mel
Orlando, FL
www.melwade.com/teardrop
“The illiterate of the 21st century will not be those who cannot read and write, but those who cannot learn, unlearn, and relearn.” -Alvin Toffler
crazycyclist
Images: 24
