Stainless Steel Micro-Airstream behind motorcycle
53: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Dec 01, 2013 5:17 pm
The last weekend I mounted the small LED rear/brakelight units and the LED indicators to the sheet and soldered all together.
The wires are connected inside two little boxes left and right of the lasagne dish.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
54: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Dec 01, 2013 5:23 pm
Today I bent the lower bar inside the stern sheet, fixed the sheet with clecos to the trailer and clamped the bar inside the sheet to drill the holes.
Her you can see the sheet from inside after drilling.
After deburring all the holes, I clecoed it all together and began setting the rivets. Here it is finished.
1977 Eriba Troll
ST1100
Images: 199
55: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Dec 01, 2013 5:29 pm
Then turned the trailer. Next step is to build the wheel houses to finish the platform trailer.
But that continues next weekend :)
1977 Eriba Troll
ST1100
Images: 199
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby KCStudly » Sun Dec 01, 2013 9:28 pm
Very nice. :thumbsup:
Postby S. Heisley » Sun Dec 01, 2013 9:54 pm
Tom, you are making art with metal. :o :applause:
Postby Steve 70 » Sun Dec 01, 2013 10:20 pm
I can't wait to see this finished. :awesome:
Excellent work!!!! :thumbsup:
Steve 70
Images: 78
56: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Dec 07, 2013 3:00 pm
Cold wind and snow outside, so first of all I stuffed my wooden garage doors with styropor, so I can work there over the winter.
The sleeping box will become too big to get it out of my warm and dry room upstairs.
So I have to continue here outside with warm cloth and cold fingers.
1977 Eriba Troll
ST1100
Images: 199
57: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Dec 07, 2013 5:47 pm
First step today is to cut the wheel arch with a hand saw. Perfect cut, deburred and three holes drilled to rivet it into place.
1977 Eriba Troll
ST1100
Images: 199
58: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Dec 07, 2013 5:52 pm
Then cut four angles from a piece of aircraft duraluminum to join the wheel arch from inside the wheel house with the lower front and stern bars.
Then riveted the first side together.
1977 Eriba Troll
ST1100
Images: 199
59: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Dec 07, 2013 6:01 pm
Then cut the second wheel arch and fitted it in the same way into the other wheel house.
That was the last piece of aluminum at the base trailer.
Next weekend I will cut the stainless covers for the wheel houses and get more rivets to finish both sides.
Today I ran out of rivets.
1977 Eriba Troll
ST1100
Images: 199
Postby ST1100 » Sat Dec 07, 2013 6:09 pm
Thanks KC, Sharon and Steve for your comments.
It's nice to know, there are people outside in the world which like my work :)
Good nite - it's after midnight now in good old Europe !
1977 Eriba Troll
ST1100
Images: 199
Postby Junkboy999 » Sun Dec 08, 2013 11:29 pm
Looking good Tom.
Hope your stay warm. My Puppy and I are wrapping bundled up for warmth, it snowing tonight, my lights in my shop will not stay on, just flicker. No work out there until spring for me.
Junkboy999
Images: 52
60: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Wed Dec 11, 2013 8:37 am
Found finally at iibay a stainless ball with 60 cm (2 ft) diameter for an affordable price (120 Euro).
From that ball I will cut the four upper corners for my trailers skin. :D
No problems with sealing seams !
1977 Eriba Troll
ST1100
Images: 199
Postby KCStudly » Wed Dec 11, 2013 9:12 am
You are having a ball building, an I am having a ball watching! :lol: :lol:
Postby mezmo » Thu Dec 12, 2013 1:37 am
Would you have a link for the SS ball ? It might be useful
to someone on another forum I know of.
Cheers,
Norm/mezmo
mezmo
Images: 194
