48Rob wrote:Got the struts installed, no more prop rods![]()
Rob
Love that Tear!!
Rob
Grant Whipp wrote:...Second, notice that in the closed position, the pressure from the spring/gas-charge is actually pushing the hinge components apart. When mounted in the proper manner, the pressure should push the hinge components together, thereby adding the additional benefit of helping to hold the lid closed.
Grant Whipp wrote:...When the seals fail (and they WILL fail), nasty fluid leaks out...
grantstew8 wrote:I've found an actual formula for gas struts on a UK site
Download the pdf and go to page 4. You'll need to convert to metric but it's the first time I've found something like this.
[url]http://www.albert-jagger.co.uk/portals/0/010_b1_b_section.pdf
[/url]
