Building the "Heart of Gold" - Done 3/9/2014
Re: Building the "Heart of Gold" - started!
Postby drewh1 » Tue Dec 03, 2013 12:24 pm
Started out attaching the door latch with wood but threw out the idea and made these metal brackets instead. Now I am ready to skin the hatch and will apply the outside skin first. The door mechanism feels much more solid with metal brackets.
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby RandyG » Tue Dec 03, 2013 6:10 pm
Nice, looks real solid. How is the action of the latch? Does it pull the hatch in or do you need to push while you turn? I was thinking of using the same latch.
Randy
RandyG
Images: 115
Postby drewh1 » Wed Dec 04, 2013 2:26 pm
Hi Randy - thanks! it is very solid. Following the advice of some of the other threads, I am not going to position the rod holes and the latch slot until everything is assembled and the hatch seal is in place. Then I will close the hatch with a small amount of pressure, ensure that the seal is compressed and mark the holes and slot. It is recommended to use lipstick or some other marking substance on the tips of the rods to mark the holes. I am also going to drill the holes at a slight angle so that the rods will pull in when engaged. I'll also make some aluminum plates to cover the holes and help guide the rods into the sides.
You might also notice the hatch mechanism is upside down and backwards. I am not sure how it is usually installed but this is the only way I could get enough depth on the bottom latch to make it secure. Putting it in this way gave me about an inch of depth to where the blade will hit the floor when the hatch is closed. I had to straighten the blades of the latch a bit to make this work. Hope that is helpful, if not I can try to get you some more detailed photos.
I like the idea of having three points where the latch mechanism will secure the hatch. I think it is going to work great when finished.
drew.
drewh1
Images: 7
Postby RandyG » Wed Dec 04, 2013 4:36 pm
Yeah that is helpful. I had the idea of angled holes to help pull it in but havent thought about the three points. Thanks!
Randy
RandyG
Images: 115
Postby drewh1 » Wed Dec 04, 2013 4:41 pm
you probably already know this - there are two different latch mechanisms - one with just the rods, and the one I have with rods and a pivoting plate. the threeway is the one to get.
drewh1
Images: 7
Postby Junkboy999 » Wed Dec 04, 2013 10:08 pm
It is coming along nicely Drew.
Keep it up.
Junkboy999
Images: 52
Postby drewh1 » Wed Dec 04, 2013 11:41 pm
thanks, any encouragement is always appreciated. framing the hatch felt like a big step forward. of course, there is lots left to do. And, I was going to buy a tongue box but I have realized I have so much wood left over. I will have to build one to use it up!
drewh1
Images: 7
Postby drewh1 » Thu Dec 05, 2013 7:07 pm
Super excited about this - I imitated the Camp-Inn Hatch support. It turned out great and works very easily.
drewh1
Images: 7
Postby KCStudly » Fri Dec 06, 2013 8:59 am
Very nice! :thumbsup: :applause:
Postby celticquetzel » Sun Dec 15, 2013 12:57 pm
Wow. A true beauty. Thanks for sharing all the great ideas and progress photos. Can't wait to see the rest. :)
celticquetzel
Postby drewh1 » Sun Dec 15, 2013 6:43 pm
Thanks for the complement! I am actually seeing light at the end of this tunnel. Did a lot of the wiring this weekend. Then I turned out the lights in the garage and sat in it flipping the lights on and off ;) I realized I need some kind of mood lighting for those special nights!
drewh1
Images: 7
Postby aggie79 » Mon Dec 16, 2013 10:09 am
Fantastic! You're in the home stretch now. The Camp-Inn style hatch support is awesome!
Postby drewh1 » Mon Dec 16, 2013 1:37 pm
Well Tom, coming from you, that is a real complement! Your build and build journal have been a big influence, especially the way you built the ceiling separately, really worked well for me.
Happy Holidays!
drew.
drewh1
Images: 7
Postby rand_98201 » Tue Dec 17, 2013 1:26 am
Ive been following along with this build and youre doing a great job.
rand_98201
Postby drewh1 » Tue Dec 17, 2013 11:28 am
Thanks!
drewh1
Images: 7
