Scamper conversion in Off Road Multi
Postby Globetrottermike » Sun Nov 17, 2013 11:30 pm
Here is the first pic of the camper after i pickup for free from a buddy :D
114392 8)
here pic after clean out
114393114394114395114396
the weather makes is a bit harder to work on the trailer but will keep fighting :)
Logic will get you from A to B. Imagination will take you everywhere.
Globetrottermike
Images: 46
Re: Scamper conversion in Off Road Multi
Postby KCStudly » Mon Nov 18, 2013 8:35 am
That's a good looking chassis to start with. :thumbsup:
Postby Globetrottermike » Wed Dec 04, 2013 10:06 pm
Here is already the first Problem :o ,Well not really a problem just have to change the Axle idea in general :NC ,so what you see on the pic is the axle how she was build by the trailer manufacturer.Works on roads just fine ,but that's not what i want...
114942
Here is a draw how i want to have the axle
114943
i thing i marked the U Clamp upside down the axle has to come under the spring not on top.
maybe we have to exchange the axle, as you may can see, at the first pic ,the axle is a Drop - Bolt Axle
So we will see as we go :thinking:
Mike
Globetrottermike
Images: 46
Postby Al in PA » Thu Dec 05, 2013 7:40 pm
Dexter makes an axle flip kit to relocate the springs above the axle. I don't know if you have Dexter axles on your Skamper frame, but it's worth checking out at any RV dealer.
Al in PA
Postby Globetrottermike » Sat Dec 07, 2013 5:01 pm
Dexter hm
I have to look in to that,but thanks for the tip
Here is a pic made with the cellphone (low res)
outriggers cut off and on post's
115014
disassembled axle
115015
the furnace is not working 100 % in the shop so it will be a early day off
quick weather up date for to guys out there
Today, 7 December
Increasing cloudiness this afternoon. Wind becoming west 20 km/h this afternoon. High minus 18C/4 F. Wind chill minus 33 C/ -27F
see u mike
Globetrottermike
Images: 46
Postby Globetrottermike » Sat Dec 14, 2013 11:58 pm
Here are some new pic's welding at the frame :twisted: (frame is upside down)
115220
115219
frame slide together and the top frame part is 48 inch long and ready for the hangers to weld on :)
115218
115216
front hitch part is now level with the frame,
the A-Frame Trailer Coupler part will be exchanged for a 3 inch Adjustable Tow Ring and a Pintle Hitch
115217
Back bumper is 4x4 .3/16 should be strong enough for the back lights and 12 x 2 in. Hitch Receiver Tube
all the wires are going through the trailer frame and meet in a junction box somewhere in the front
115221
more is coming :D
see u Mike
Globetrottermike
Images: 46
Postby Globetrottermike » Mon Feb 17, 2014 11:10 pm
just checking in
the progress is slow :( but still working on the trailer very little time :(
cu mike :R
Globetrottermike
Images: 46
Postby Globetrottermike » Sun Mar 02, 2014 10:54 am
Hi Guys
Yesterday worked a little on the trailer :) here are some pics about the progress 8)
Cuttings for the lights
117296 117297[album]
117298[/album] 117299
oh boy, 4 h only zip disk ,
had to replace the saddle on the axle
was 1/2 inch out off center,moved it 1/2 inch to the left and 1/2 to the right side axle is (was 62 inch) but i needed 63 inch
117304 117303
have to place the axle in her final place and weld the hanger on ,should happen this week,
the last pic off the day is with welded bumper on the frame incl receiver hitch
117300
see mike :)
Globetrottermike
Images: 46
Postby Globetrottermike » Mon Mar 17, 2014 10:43 pm
Hi Guys
finally it some work done :D
Some welding in the frame to hold 3/8 plywood in place ,for the under belly ,basic standard plywood for water protection from the road and so on,main job for this wood is to hold the 3 inch Insulation in place ,the wood need a black paint job next week before we flip the trailer,the black paint on the frame is just rust primer for in between the wood layers because cant to it later when the wood is mounted ,
117996
117995
there is no pic with black paint on , forget to load the pic in the gallery :SH
117993
plywood is a 1/8 inch higher than the frame :x
some silicone as a extra seal ,the rubber back paint stuff will do better just a extra
117992
plywood fixed with self tappers 10x1 Inch (pre drilled with 9/64 drill bit )
trailer with 2 piece plywood installed
117994117991
ok call it a day :D :D :D
see u mike
Globetrottermike
Images: 46
Postby Globetrottermike » Tue Mar 18, 2014 10:37 pm
Hi Guys
here are some more pic s
trailer upside down,with the body box,and plywood finish at the under belly 8)
with out the sealing (Black stuff) on the underside
118030
118032
Just need seal it up and take care of the seams 8)
cu mike
Globetrottermike
Images: 46
Postby Globetrottermike » Wed Mar 19, 2014 11:17 pm
Hi Guys :D
Underbelly of the trailer is done, :wine: :beer:
Here are some pics
first pics are the mounting plates for the Stabilizer Jacks ,a bit hard to see on the back tear paint stuff
118056
welded the nuts in the holes
118058
118057 118059
last pic of the day
let it dry maybe a second layer of undercoat,mount the axle, double check all seems, wire the lights in ;)
118060
see u mike :hammer:
Globetrottermike
Images: 46
Postby Globetrottermike » Sat Mar 22, 2014 9:37 am
hi guys
here is trailer flipped and axle mounted and tires on and fender (just temp)
118124
8) 8) 8)
know comes a bit welding on top and wire the lights in :twisted:
see u mike
Globetrottermike
Images: 46
Postby Globetrottermike » Mon Mar 31, 2014 10:41 pm
hi guys here are some pics :pictures: of the progress :D
118478
118479
118480
118481
118482 :pictures:
cu mike
Globetrottermike
Images: 46
Postby Globetrottermike » Wed Jul 09, 2014 10:23 pm
still working on the trailer,but have no time for nothing really ,give it a break for a couple month 8)
cu mike
Globetrottermike
Images: 46
Postby aggie79 » Thu Jul 10, 2014 8:47 am
Your trailer is gorgeous! :applause: :thumbsup: :applause:
I can tell this isn't your first rodeo in metal fabrication. I can't wait to see the trailer shell construction.
