My TD/Benroy Project
Re: My TD/Benroy Project
Postby tscarbroughdc » Wed Jul 10, 2013 9:06 am
Sorry I havent posted in a while...Ive gotten my frame painted, but had an allergic reaction to the spray paint! haha...So I took some time off. I hope to resume shortly!
tscarbroughdc
Postby 2bits » Wed Jul 10, 2013 10:33 pm
You are off to a good start! If you have a good tight seal on the wood to the frame you will probably be OK, but you could run a bead of silicone along the joint to help keep any water from getting in too.
Regarding HF trailers, For my second "Teardrop", I used the super small 3x4 Harbor freight trailer ($140). I wanted the wheels further back so it worked out great to weld in some angle iron to the front to make the trailer 3x7. Since it was only three foot wide, I got some spacers and raised the frame off the axle 2" and lowered the fenders and viola' I was able to put a 4x7 sheet of plywood right on top of it, and build over the wheels without them getting in the way. The same concept would work to build a five wide on a 4x8 trailer too.
It ain't sexy, just an air conditioned and heated hard sided tent!
Good luck on your project and be careful with that paint!
Thomas
2bits
2bit Member
Postby eddiegrey » Sat Nov 30, 2013 5:09 am
I am seriously considering purchasing the Ty-Dean plans. How hard would it be to modify the plans and use the NT 5x8 trailer??? Doesn't seem like that would be all that difficult.
eddiegrey
Postby tscarbroughdc » Sun Dec 08, 2013 3:45 pm
Well the Thank You! dean plans aren't bad. They are pretty easy to follow although I have changed a few details from seeing things on this site. Plus I ended up buying 5 different sets of plans. I have emailed they guy who put the Ty Dean plans together and he has been fast to respond with help!
tscarbroughdc
Users browsing this forum: Bing [Bot] and 6 guests
