deans TD build
deans TD build
Postby dean_petley » Mon Jul 15, 2013 4:31 am
g day guys and girls i am looking at planing out my new tear drop
what i wont from this trailer is to
sleep two people (in comfort)
light weight
good storage ie water tank about 20lt and food storage ie 60 lt esky to keep the rum cool :beer:
also nothing to big the tow car inst that big or powerfull or even fitted with a tow bar yet :roll:
if any one thinks that thay might have a plan to fit this list dont befraid to let me know tomorow ill measure up a base size im happy to live with
have funn
dean_petley
Re: deans TD build
Postby mudcrab » Mon Jul 15, 2013 5:34 am
Hello Dean
I'm in western Sydney and have almost finished my TD build.
Happy to answer any questions if you think I may be able to help
Nev
mudcrab
Re: deans TD build
Postby rebapuck » Mon Jul 15, 2013 8:05 pm
You have the end result figured out. Now you just have to get there. This is the place to be for that. Welcome.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Re: deans TD build
Postby dean_petley » Tue Jul 16, 2013 5:28 am
mudcrab wrote:Hello Dean
Nev
G day Nev im in west Sydney out colyton way and if you think you could be of any assistance please dont be shy
i thinking of making the walls and frame hoops lid and door out of aloy
the chassis will still be steel
1 to keep the weight down
2 because i work with the stuff all day building toolboxes and aloy trays for utes ect ect
tonight im just going to put pen to paper and work on a basic lay out of frame walls chassis
have funn
dean_petley
Re: deans TD build
Postby dean_petley » Tue Jul 16, 2013 6:12 am
a rough section of the roof wall and hoop i am going through the extrusion book tomorrow to see what i can use to join and seal the roof and wall and to affix the sheet to the hoop i am thinking aloy 6mm rivets
have funn
dean_petley
Re: deans TD build
Postby alaska teardrop » Tue Jul 16, 2013 7:14 am
    Hi Dean,
    Since my fabrication methods are similar to what you are proposing, I look forward to watching your progress.
    Here is a link about building the Northern Lite Traveler the a may give you some ideas on building lightweight:
    :peace: Fred
alaska teardrop
Re: deans TD build
Postby mudcrab » Wed Jul 17, 2013 9:51 am
Dean
I'm in 7 Hills
I sikaflexed 3 mm sign board onto my wooden frame and used standard caravan extrusion to seal the wall/ roof joint.
Very happy with the smooth look. Don't know how to add a pic or I could show you
My last job is to make the aluminum mudguards (using 3mm 5bar plate). Would you be able to recommend a business that could weld the corners for me
Nev
mudcrab
Re: deans TD build
Postby dean_petley » Thu Jul 18, 2013 3:54 am
alaska teardrop wrote:
    Hi Dean,
    :peace: Fred
that is a very good read and is more or less the basic construction that i was tinking of i am going down a slightly different road with suspension im thinking leaves just because AUS is a big place with lot and LOT of nothing inbetween and a leaf set up is about as rugged as you can get and parts are easyer to get / make on the side of the road if it comes to that :frightened:
have funn
dean_petley
Re: deans TD build
Postby dean_petley » Thu Jul 18, 2013 4:09 am
mudcrab wrote:Dean
I'm in 7 Hills
Nev
g day nev where did you get the standard caravan extrusion to seal the wall/ roof joint.?
and by 3mm 5 bar plate do you mean checker plate ? Image
and as far as welding it i can do that if your ever about weatherill park Penrith way ? ill take it to tafe you can have it back next week
have funn
dean_petley
Re: deans TD build
Postby mudcrab » Thu Jul 18, 2013 1:16 pm
Dean
Very kind offer re welding. Will contact you next week if my search round here turns up nothing
Got my doors hatch and cover strip from Hans Vans on the Central Coast (Hans was very helpful)
But I am sure you could get the cover strip from any caravan repair place such as Barnes on the Hume Hwy Lansvale
Cover strip comes in 5 m lengths with black or white plastic insert so a bit tricky to transport.
Got my durometer for hatch seal, struts, centreflex hinge and hardware from Naughtons in wetheral park.
They may be worth a try for the cover strip
Nev
mudcrab
Re: deans TD build
Postby dean_petley » Mon Jul 22, 2013 5:31 am
mudcrab wrote:Dean
Nev
Naughtons in wetheral park. i got a lot of stuff for work through them there just down the road
also actiion ally do a table profile in aloy that will do the trick i think for sealing the roof and side
have funn
dean_petley
Re: deans TD build
Postby dean_petley » Mon Jul 29, 2013 4:12 am
ok i have crunch a few number and i have a chassis that i am happy with as far as dimentions
my panel van is about 1700mm wide 1600mm tall and about 4500mm long
so i thinking of making the chassis for the tear 1550mm wide and 3500mm long
i have alowwed 2000mm for sleeping as i an 1770mm tall so i have room for a pillow and 400mm for a galley and storage with some pull out draws used for counter space but ill work that out after i have the chassis and walls up see what looks good to the eye
but i dont know how to load up the file or how to turn it into a jpg or similar file for uploading
i have modified the profile of the grumman 2 this i have not drawn up just yet its all on paper i have deleted the rear lowest radius for more internal room and i have taken the 15 inches of flat roof out from the middle
have funn
dean_petley
Re: deans TD build
Postby dean_petley » Tue Dec 10, 2013 3:57 am
ok kids it been a while i have been busy with work and family BUT
im back for an update
built the chassis from 50 x 75 x 1.6mm rhs with 30 x 30mm rhs
this was the basic layout on a bench at tafe
welded end section
goose neck tacked in place
first lot of floor spans tacked in place
end caps / strengthening plates for the goose neck
all together and on wheels
with some alloy sheeting in place
and thats about as far as i have gone my next job is to find someone who can roll the steel hoops for the side profile so i can weld them inplace then the spreders then sheet the body
but i am having real trouble finding someone who can roll the the profile i have drawn on autocad i think i might need to build a press and do it my self
have funn
dean_petley
Re: deans TD build
Postby michaelrsydney » Tue Dec 10, 2013 8:27 am
Nice work Dean! Not the first time you used a welder eh? :)
I look forward to seeing the profile you choose to build. My concern with your plan to frame it in 25mm square tube is that you have very little cavity space for insulation, especially in the roof. Ideally you need a combination of bulk insulation (foam or such) and an aluminium reflective surface facing an airspace of at least 20mm.
If you still need to buy hinge or corner strip I think Aussieteardrops are discounting some parts. I got my hurricane hinge and strip from there, though the 4 meter corners needed cutting to size before it could be sent!
http://www.aussieteardrops.com/
Are both your old Holdens EH? Look great!
Michael
Sydney
Australia
114996
Frog and Toad
michaelrsydney
Images: 77
Re: deans TD build
Postby Junkboy999 » Tue Dec 10, 2013 3:39 pm
Great looking frame. I’d say just go for it and make you own bender. It is hard to find a shop that will do “Piece Work” ( just or of two parts ) any more. They all want full drawn out planes bigger contracts.
home made tube bender
https://www.youtube.com/watch?v=RBWXQ0t5Mw8
Junkboy999
Images: 52
