interior walls
interior walls
Postby bobnlyd » Thu Dec 19, 2013 12:14 am
what do you use on the interior walls if you dont want the wood finish...i live in the so cal desert so it must withstand heat...would a cloth wallpaper work in heat
bobnlyd
Re: interior walls
Postby KCStudly » Thu Dec 19, 2013 8:11 am
Hull liner (carpet like) applied with contact adhesive is popular with some people (others think it traps odors and moisture).
Here's a youboob vid showing it going on the ceiling of a boat cabin; same technique.
Myself? I would probably go with a soft backed vinyl or fabric instead, and I would make them as panels that could be removed at a later date in case I ever wanted to reupholster (possibly using the chip board/poster board that GPW used on the inside of the Foam Stream as a backer board). I think Bob Henry did the interior of one of his this way by wrapping fabric around insulation board and just pressing it snugly into place.
Re: interior walls
Postby bobhenry » Thu Dec 19, 2013 8:14 am
KCStudly wrote:Hull liner (carpet like) applied with contact adhesive is popular with some people (others think it traps odors and moisture).
Near the bottom of this link is how I did mine
http://www.tnttt.com/viewtopic.php?f=50&t=38489&start=75
here is a teaser...........Image
