Dave wrote;
Would you (personally) line a set of wood fender with metal? Or would maybe some spray-on undercoating over fiberglass suffice and be preferable for the inside wheel wells...
48Rob wrote:
My vote would be to simply seal the wood well with several coats of oil based paint or urethane, then give it surface protection with rubberized undercoating.
Wood wheel wells are not a new thing, and work best when left uncomplicated.![]()
Rob
Juneaudave wrote:I think the biggest initial probem I have is getting some gross overall dimensions so that the proportions are right.
Juneaudave wrote:Stripping might be difficult, and a guy certainly doesn't want the weight, but one of the techniques I thought would make it possible would be the generous use of a "sabot" (something a fella in Belgium described when building his canoe).
angib wrote:Juneaudave wrote:I think the biggest initial probem I have is getting some gross overall dimensions so that the proportions are right.
That's easy, I'll have that for you tommorrow - unless it's sunny and the bicycle beckons......
I'll keep working on this.
Andrew
