Heavy load in trailer or vehicle?
Postby Treeview » Wed Dec 25, 2013 8:03 pm
Since the focus here is trailers I'm sure that the answer to my question will have been thrashed out before.
Next week I'm moving from NC to MN. Don't question my sanity! If I could find decent work I'd stay here, this is a great place to live. I'm from Minneapolis so I know what I'm going back into :?
OK...I'm making my initial move using my ToyBox hauling a 6x10x4' tall trailer.
It seems like the best loading strategy would be to put more weight in the ToyBox and the high volume/lower weight goods in the trailer.
Is there a reason to load the other way around? Heavy trailer/light truck?
Treeview
Images: 30
Re: Heavy load in trailer or vehicle?
Postby MtnDon » Wed Dec 25, 2013 8:55 pm
I'd go with more wt. in the TV as long as it was within the weight limits
MtnDon
Images: 24
Postby Corwin C » Wed Dec 25, 2013 9:07 pm
In my experience it's all about balance ... if the TV is at 90% of capacity, the trailer should be at 90%. Most of the time the TV will be heavier than the trailer, although, in some cases (multiple axle trailer w/ brakes) the trailer could be heavier than the TV. Make sure that it stays within the maximum GVWR for your vehicle combination.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby AZ9 » Thu Dec 26, 2013 12:12 am
My truck load limited is 1450lbs, but can pull 7800lbs trailer--thus, I would put heavy load in the trailer--to save gas.
Benedikt & Inger
2007 Haulmark 7X14 Cargo converted Camper
2007 Fleetwood Sequoia Popup Camper
2008 Toyota Tundra 4X4
AZ9
Postby Treeview » Thu Dec 26, 2013 12:23 am
I'm not considering overloading. I have more volume than load capacity.
It seems that shifting weight to the truck would make acceleration and braking more efficient. I wonder how the physics work out on this?
Treeview
Images: 30
Postby Irmo Atomics » Thu Dec 26, 2013 5:35 am
We pack as much weight in the tow vehicle as practical with the weight in front of the rear axle. I feel like the heavier the tow vehicle is compared to the trailer, the more the tow vehicle can be in control of the trailer, instead of the other way around.
Bob
Irmo Atomics
Images: 64
Postby jeff0520 » Thu Dec 26, 2013 10:04 am
The thing that is most critical is that 60% of the weight in the trailer should be forward of the axle. That will avoid problems with trailer sway. Second, the gross weight of the TV (vehicle empty weight + cargo carried in the TV + tongue weight of the trailer that is resting on the TV) should be greater than the weight on the trailer axle. That is another stability issue. It's quite disconcerting to have a trailer heavier than the TV pushing you around if you can avoid it.
I hope that is helpful
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby Dale M. » Thu Dec 26, 2013 10:30 am
Is your "ToyBox" the truck in your avatar?
Dale
Dale M.
Images: 18
Postby Treeview » Thu Dec 26, 2013 11:21 am
Yes Dale.
there are a few pics in my signature link.
Treeview
Images: 30
Postby grant whipp » Thu Dec 26, 2013 2:21 pm
Very important question, here: does your trailer have brakes? If so, then the generally accepted "rule" if you will, is that you can always pull more than you can haul ... my F-250 can pull more than 10K# but can only haul about 2K# or so. BUT, brakes on the trailer are critical!
How ever you end up, be careful and good luck! As always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby PKCSPT » Thu Dec 26, 2013 8:24 pm
I know very little about loading but let me welcome you back home to Minnesota.
121172 116946 159644
PKCSPT
Images: 61
Postby Treeview » Thu Dec 26, 2013 8:30 pm
Hi PKCSPT
Thanks! I'll be glad to be settled in somewhere!
The trailer has hydraulic surge brakes but they're not plumbed. In the spring that'll happen.
I've been loading trucks and trailers for 40 years. Working most of my life as an arborist means that I've had to move lots of heavy loads on various trucks and trailers. I learned the importance of loading tongue heavy when a load of logs on a pickup box trailer got whippy going into a freeway tunnel [near the old Guthrie Theater in Minneapolis]. That was 39.75 years ago :D
My plan is to load more based on volume and the need to protect from the weather. Like I said, I have enough cubic volume to overload both the truck and trailer. One of my kayaks and/or canoe may make this initial move if I have capacity.
Thanks for the input, a lot of it had already been considered,
Treeview
Images: 30
