by Martinjmpr » Mon Dec 30, 2013 2:14 pm
Although Liz and I both love Bubbles, I'm just wondering what would be considered the "next step up" from a teardrop?
Here's why I'm asking: We've done a lot of camping over the past 2 years with Bubbles, and we have a bunch of trips planned for next year (including several TD gatherings!)
But we both realize that sooner or later we're going to get tired of crawling in on our hands and knees, and that as our granddaughter gets older, sooner or later we're going to want to take her with us.
So, I'm just kind of "looking down the road" to see what options we should consider when we "outgrow" Bubbles.
We belong to the Southwest Vintage Camper Association and we have seen some very nice restored vintage campers from the 50's, 60's and 70's. But I'm not sure if I want to take on the amount of work neccessary to restore one of these old trailers. I've heard horror stories about water damage, electrical problems, floor rot, frame damage, etc, and when I look at these vintage trailers, the thing that occurs to me is that "this is like having another house to maintain!"
See, one of the things we both like about Bubbles is that she's simple: She has slab plywood walls (no "sandwiching" of a frame between inner and outer panels), no electrical other than her tailights, and no gas. The vent fan is solar and we use battery powered lights. The frame is simple and stout and if a light needs rewiring, I can access it easily from under the trailer. There is no running water and no holding tanks for gray or black water. As a result, she doesn't require a lot of maintenance, which we both like.
So I'm just wondering if anybody out there makes a stand-up trailer that is as simple and basic as our Bubbles. Most of the standup trailers I see have gas, internal electrical power, and running water, all of which need to be carefully maintained. There is also the issue of weight: Bubbles weighs about 1,000lb, and I don't really want to pull anything that is much heavier than that, I would say maybe 1500lb max.
I suppose we could buy an old trailer and just not use the sink or stove (or even disconnect or remove them) but we would still be faced with issues of leaky roofs (which seem to be a real problem with old trailers), chasing down electrical gremlins, etc.
I guess in my mind, I would see something like one of the small fiberglass-shell trailers like the Burro, Casita or Scamp, but with a very basic interior.
I know the stock answer here is "build your own!" but I don't know that we have either the time or the skills to do that. It took us 3 1/2 months of using virtually all our free time to basically "rebuild" Bubbles, and we didn't really do anything to the exterior structure, other than to sand it and protect it. Building a trailer from the ground up is, I'm afraid, a little beyond our current abilities.
I'm sure we're not the only people to ever have this thought, so I'm curious, for those of you who did, what was your solution?
