Whats the size and weight of your TearDrop
Postby Tripmaker » Thu Jan 17, 2008 2:34 pm
5 X 10 when I had it weighed partially loaded it was 1,320 lbs. I'm guessing fully loaded with gear (no food or clothing) 1,400 lbs. 170 lbs on the tongue.
Jim
Tripmaker
Images: 59
teardrop weight
Postby Oregonian » Fri Jan 18, 2008 9:08 pm
Mine is 4x4x8 and fully loaded for 1 person and his dog, weighs 1020 lbs
Bruce JSC
The love of teardrops brings people together
where have you gone if you haven't left
Oregonian
teardrop weight
Postby Oregonian » Fri Jan 18, 2008 9:09 pm
Bruce 87 lbs tongue weight JSC
Oregonian
Postby angib » Sat Jan 19, 2008 1:56 pm
This is all weights down to Warpony's below.
Danny's 'ton of bricks' trailer has distorted the 5ft line a bit!
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby mallett » Sat Jan 19, 2008 2:07 pm
5' x 10'
Every man's work, whether it be literature or music or pictures or architecture or anything else, is always a portrait of himself.
- Samuel Butler (1835-1902) British writer.
mallett
Images: 61
Postby WarPony » Sat Jan 19, 2008 3:32 pm
OK, I'll play........
First one, 5X8 and is around 950 LBS.
Second one is also a 5X8 and is around 625 LBS.
Jeff
WarPony
Images: 289
Re: Whats the size and weight of your TearDrop
Postby citylights » Mon Dec 30, 2013 11:24 pm
Do I get the prize for heavyweight? Based on the generic benroy plans, 5 x 10 weighed in empty at 1750 lb.
citylights
Postby Vedette » Tue Dec 31, 2013 1:01 am
John
You have been busy! :thumbsup:
Should have been following your build journal I guess?? :oops:
Good looking rig!
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby jonw » Fri Jan 03, 2014 9:54 am
5 x 8 foot woody with aluminum roof, torsion axle, memory foam mattress (topper) - 720 lbs. with all gear.
jonw
Titanium Donating Member
Images: 163
Postby webbaldo » Fri Jan 03, 2014 11:32 am
8x4 alu skinned plywood, 2"x2" box chassis, torsion axle. small cabinets inside and full galley
comes in at about 320kg (sorry not sure in old money)
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Postby S. Heisley » Fri Jan 03, 2014 9:29 pm
The latest thread on size and weight was last updated on September 1, 2013; but, these things get buried quickly.
Here's an address to click on to see the 108 trailers listed there:
viewtopic.php?f=2&t=56787
Postby Weirdnerd » Sat Jan 04, 2014 1:10 pm
Mine is built brutalistic, insulated, propane, battery, stove with oven, water, and the whole pantry/pots and pans. Six feet wide, ten feet long, four feet tall ( over the trailer) or six foot tall from the ground, weighs 1740 lb, and tows very nice with a 1991 4runner.
This is my build thread...
Weirdnerd's teardrop
Weirdnerd
Postby Shadow Catcher » Sat Jan 04, 2014 4:36 pm
All aluminum frame 6X10 at 1400# prior to a bigger battery solar panel and a few other items.
Postby canned o minimum » Wed Jan 08, 2014 2:10 am
I recently purchased a "one off" designed and built by Roly Nelson. He called it the "Shrunk Bunk", but since "I" now own it, I call it thje "Squeeze Box". It measures 40 inches wide by 4 ft long and near 24 inches tall. We figure it weighs in round 200-250 lbs. Yes, it IS a Teardrop and once "deployed" it measures 40 inches wide by 7 ft long and 4 ft tall WITH a full galley !
canned o minimum
Postby nhstt » Wed Jul 09, 2014 9:41 am
canned o minimum wrote:I recently purchased a "one off" designed and built by Roly Nelson. He called it the "Shrunk Bunk", but since "I" now own it, I call it thje "Squeeze Box". It measures 40 inches wide by 4 ft long and near 24 inches tall. We figure it weighs in round 200-250 lbs. Yes, it IS a Teardrop and once "deployed" it measures 40 inches wide by 7 ft long and 4 ft tall WITH a full galley !
Do you have any pictures of this?
Mine will be 4x8 built over a 40"x 48 harbor freight like Roly's stacker the bed is only 46x72. the galley is removable. This week the hatch goes on :applause:
Karen at the Ladybug-out build journal viewtopic.php?f=50&t=55602
nhstt
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
