Pat
loaderman wrote:ArkPat any pics of your build?
linuxmanxxx wrote:With the display of how simple paper and elmer's glue can more than triple the load on the foam, why does everyone get their head wrapped around using heavy materials on the skin such as 1/4 plywood? I've used 1/8" luan on all mine and can walk on it at almost 200 pounds so I'm just confused why people keep using 1/4 and 1/2 in their torsion box builds.
Lonewolf42301 wrote:linuxmanxxx wrote:With the display of how simple paper and elmer's glue can more than triple the load on the foam, why does everyone get their head wrapped around using heavy materials on the skin such as 1/4 plywood? I've used 1/8" luan on all mine and can walk on it at almost 200 pounds so I'm just confused why people keep using 1/4 and 1/2 in their torsion box builds.
Just what I've been waiting for, someone who used 1/8" material.... Was it strong enuf to walk on with a 5' width in trailer without any bracing under it?
Gizzmo wrote:As promised I said I would post my results
Material was one and a half inch foam 1/8 inch pressboard out of the bottom of the dresser drawer glued with tb2
Very strong I could put all of my 170 lbs on it with out bending at all then I jumped up and down on it, still fine then I really started to jump up and down on it with only one foot before the top layer broke it took a few more jumps before the bottom layer started to separate at witch point I stopped
Remember that this is only 7 inches wide and two and a 1/2 foot long I have no doubt that this would hold up extremely well if sandwiched between 1/4 inch wafer board OSB
Users browsing this forum: DrAlvarez and 16 guests
