be_a_jayhawk wrote:Love the work I have a 5x10 I found on CL I chopped as well. Hope it warms up soon so I can get back to it.
be_a_jayhawk wrote:I do worry about sealing the base as mounting the side walls over the side wont work with the wheel wells but I will become friends with a couple tubes of caulk, sealer, and paint. Where there is a will there is a way!
Esteban wrote:Lauren you can run wiring in the galley bulkhead, the ceiling, side walls, and or through the cabinet dividers...if they have a hollow core. Or a false front.
lfrazer98 wrote:Good idea! We will make sure to mark everything! I believe we are doing 3 separate systems: the trailer lights, 12V cabin, and 120, just in case there is an electrical hook up. Not planning on inverters/converters, and such. So, it should be easy. Famous last words, right?!![]()
lfrazer98 wrote:As an aside, Any woody builders out there have any hints for the exterior skin on a 5 x 10 as far as the seam where the 2 pieces will meet? Thought I would look into finding a 4 x 12 sheet a plywood, just in case they existed. I actually only need 4 x 10 1/2... I really want woody sides and may just have to hand select my exterior skins carefully. Looking at birch because I like the grain.
