lrrowe wrote:
One model has a freezing protection circuit which draws less then 1 amp 120 AC. Could work if you have a way to keep a battery recharged when off the grid.
MtnDon wrote: Most are a pain to drain and drain well enough if you need to worry about freezing weather. I know a couple people who have had their on demand heaters freeze and crack the metal tubing even though they blew them out with compressed air. That is my main beef with them.
MtnDon wrote:My plan is to do a similar thing. I am thinking along the lines of pumping the heated water through a finned assembly like an auto heater core or a auxiliary transmission oil cooler.
