formeryooper wrote:Anyone running a nu way? Do they pump out decent heat? Can I reasonably hope to pull 200 degrees or so difference between interior and exterior temp with their big stove in a small well insulated trailer?
GuitarPhotog wrote:formeryooper wrote:Anyone running a nu way? Do they pump out decent heat? Can I reasonably hope to pull 200 degrees or so difference between interior and exterior temp with their big stove in a small well insulated trailer?
200 degrees between interior and exterior?
Do you really want a 100F interior when its -100F outside?
<Chas>
A sauna session can be a social affair in which the participants disrobe and sit or recline in temperatures typically between 70 °C (158 °F) and 100 °C (212 °F). This induces relaxation and promotes sweating.
<Chas>
jseyfert3 wrote:If you know the BTU output of the stove it should be a fairly straightforward calculation. If you let me know the size of your planned trailer, insulation type and thickness so I know the R value, when I get home I'll pull out my physics book and run the calculation.
formeryooper wrote:jseyfert3 wrote:If you know the BTU output of the stove it should be a fairly straightforward calculation. If you let me know the size of your planned trailer, insulation type and thickness so I know the R value, when I get home I'll pull out my physics book and run the calculation.
Size will most likely be a 5x10 or so, still working out the details of how much room I need versus what the jeep is comfortable towing. I'm hoping to find a friendly salesman at some point who will let me try tossing a bit of weight in a couple trailers and see how they handle. I believe the stove puts out 26000 btus. Insulation will be a function of trailer size, available space, and what I need to get her nice and toasty
Rainier70 wrote:I have a 6x12 cargo trailer that I added a NuWay 2000 propane stove to. It is on pages 4 and 5 here: viewtopic.php?f=42&t=55219&start=45
I don't even run the stove on anything past about medium, and it gets plenty warm for me when I am camping. But I am not looking for it to be a sauna.
