lrrowe wrote:len19070,
Thanks, this offers another interesting possible solution to the project. No external heat exchanger needed and no water contamination issue if you accept the premise that if the internal heat exchanger is good enough to warm up the water in the tank while driving, then it is good enough to work in reverse. Too bad one could not find out the efficiency of the exchanger.
The premium for this model over one lower cost Attwood 6 gal unit (one I found with after a quick search) is about $130 more. I will add up the cost of my various options and see which is the best cost wise.
Bob
Prem wrote:KISS = Keep It Super Simple
KIL = Keep It Lightweight
len19070 wrote:This is a way of doing this with Propane (and or Electric) But in my opinion if you have Electric...just use an electric heater?
len19070 wrote:Atwood sells a 6 gallon RV water heater with a Heat exchanger already built into the tank. Model #GCH 6A 10E, so that the RV's engine could heat the water in the water heater while driving without igniting the water heater. (using the engines heat)
This could be used in Reverse as I have seen it done back in the late 80's early 90's.
Without being hooked to the engine of course.
lrrowe wrote:I was trying to point out that one Atwood model has a separate set up of tubing that was went through the heaters hot water tank and was designed for one to use the TV's engine hot water to heat the RV tank and that in it's own way is a heat transfer device. See Len19070's earlier post. So it is another option. With the internal tubing for the designed engine coolant, the heater water and the engine cooling fluid do not mix. Hope that makes sense.
