OverTheTopCargoTrailer wrote:Heated RV water hose
good to -42 degrees F
http://www.campingworld.com/shopping/item/12-ft-pirit-heated-hose/74842
Tx River Rat wrote:OTT
I know your are the rocket scientist here and have proven time and time again how briliant your work is.
I read your article in your link and it says they can produce artifical snow up to 40 degree outside temperature if conditions are perfect. Hell I can beat that I can produce ice cubes up to above a hundred degrees in my little ice maker and dont even need 5 million plus worth of equipment to do it.
Even you will have to admit we were talking about a naturally ocurring event that didnt have refrigeration equipment involved.
Ron
roadinspector wrote:OverTheTopCargoTrailer wrote:Heated RV water hose
Here is another option. Lots cheaper but it will require you attaching it to the hose. Says its good down to -40.
http://www.lowes.com/pd_23997-72436-AHB ... facetInfo=
Earnest
lrrowe wrote:Jerry, I just sent you a PM on another topic.
but the biggest change is this time we included metal 1 1/2 studs because they glue and screw the plywood which per the dealer make the plywood almost impossible to remove without totally destroying it and leaving crap on the wood studs. Now if I do not want screwless, they can put the plywood on the outside. When I call tomorrow, I will fight this, but I do not think I will win.
This brings me to my question. Did you have a problem removing the plywood from your interior, or did you have it added to the outside? I did not ask for the plywood on the outside because I like the screwless idea though.
Bob
