To be clear, I've no hands on experience with resins or fibreglass. I have researched and read up about it.
My workshop is a few degrees above freezing and I've mixed up some polyester resin with more than the required amount of catalyst. I've laid down some glass on the underside of the mudguards/fenders and it's taking ages to set.
The leftover resin in the plastic tub has solidified but the thin layer painted on are still sticky. I did it to check if it would work....it is under the wheel arch so no-one will see it unless changing a flat.
Is this pretty normal for it to take ages to set/cure/go-off?
I expect to get my wood burning stove up and running next weekend to keep the place a little warmer.
