robfisher wrote:People don't seem to understand the inventors spirit. Don't listen to the nay-sayers. Educate yourself and try your ideas in as safe a manner as you can.
One thing to think about is the fact that propane is about 1.5 times heavier than air. If for some reason your torch blows out and the propane valve stays open will your tube vent out the unburned propane? If the tube happened to be filled and you tried to re-ignite, the results may be a bit surprising to say the least.
Be careful and have fun.
GerryS wrote:Rob, I understand the inventor spirit...more than you might think. But I also understand risk. I don't want some one experimenting when they are building a bridge it will have to drive over. Engineering principals and safety principals are just that....principals never change, and when you start to play, you can get burned. Carbon monoxide and fire aren't just minor inconveniences like a dripping waterline or a rattle under the dash. They are both things that can easily kill you. Heck, even Bob Henry has experienced problems in trailer that was a little too tight.
Mojave Bob wrote:Another wonky idea -- what about using a Zodi propane hot water heater (like the camper showers) to create radiant hot water heat? A small water reservoir, a circulating pump, and an expansion jacket, and voila!
Mojave Bob wrote:1. The end of the tube where the torch is inserted will get ROASTING hot - very likely glowing red inside the camper. The thimbles may protect the structure, but I would be concerned about having something that hot inside the small space.
2. The torch itself is designed for intermittent use. I very much doubt that it will hold up to running for hours on end.
3. Torches use a mixer vent to add air to the propane for combustion, but clean combustion only occurs when there is a good source of air around the flame. By inserting the torch nozzle tip into the tubing, I think the flame will burn very rich, which, combined with the moisture associated with propane, will cause serious soot build-up in the tubing.
I like the idea that has been presented of using a water heater burner, or something similar. Even if a propane leak will dissipate, it is still preferable to shut down the flow of propane instead of venting it to the atmosphere. A water heater burner, with a throttle valve, with a collector over it, reduced into a draft tube, should provide positive flow pressure to push the heated air through the ceiling tube, without super-heating one end of it.
By the way, I use a trucker's 12v mattress pad. I have not camped in sub-zero temps, but it heats the bed VERY nicely. That, combined with a nice down comforter, would be toasty warm. I can easily go three nights on a deep-cycle battery. If the battery were stored in semi-warmed space (in the interior of the camper with a vent to the outside), it shouldn't suffer from amperage loss due to the cold.
rowerwet wrote:Mojave Bob wrote:Another wonky idea -- what about using a Zodi propane hot water heater (like the camper showers) to create radiant hot water heat? A small water reservoir, a circulating pump, and an expansion jacket, and voila!
I have the Zodi water heater, the heater is intended for showering, it needs continuous flow to keep from overheating the water (no thermostat), more than one reviewer has complained that they couldn't shut the water off to soap up.
too bad they still don't sell the small zodi tent heater, it really is exactly what you want, http://www.zodi.com/tent-heaters
KennethW wrote:The shelf would be removable with keyhole slots and 2 screws in the side of the camper.
Mojave Bob wrote:
The tent heaters are very slick, but very expensive, and require 12v electricity, which I think is outside the design spec for our case study.
