Mary C wrote:I want to build a boat similar in materials to Rosies but I plan to design it differently I am looking at boat designs a lot before I build I am wondering how to figure the buoyancy and how to figure if I build it will it hold me above the water that is the only reason I haven't built one. I will figure it out even if it is by try and see method. what I want is similar to the mouse boat made with lots foam and more designed as short and thinner at the front but 4 inches of foam on the bottom and hold me and a little electric motor and battery along with my fishing gear. I know nothing about boats so I can think out of the box, without prejudices and all the things that can and can't be done. I can build a fishing boat where I will have what I want and it will be very light and can be used in still waters without hesitation. I can also block out the naysayers, and the ones who just like to stir up the pot so to speak. I can do it but it will be a project when I get back from my Big Out West Trip.
See I told you canvas has been used in earlier boat building. what he said!!!
There was a boat retrieved from the depths and the historian was pointing to the little patches of canvas as it was torn from the wood that it had protected the wood so well that it looked like new.
Mary C.![]()
GPW wrote:Just sayin’ ... if you have two boat builders in one room ,you know they’re going to argue about which is the better way... and due to their curmudgeonly nature , wouldn’t even likely consider our Foamies as Real boats .... merely fancy floats...![]()
Thing is here, we already Know what works !!! It’s all been tested !!!![]()
GPW wrote:Larry, I too was thinking of using bottom chine strips as protectors ...easy enough to work in some hard points into the hull for attachment/replacementhttp://www.theoaks.ca/bottomchinestrips.jpg
wagondude wrote:Well, in all fairness. They also design boats to be built a specific way with the materials they sell. They are just telling anyone not to try it with their designs. And it would be unsafe to try it with most of their designs. Canoes and kayaks would be ok, but not something pushing 50 hp.
Users browsing this forum: DrAlvarez, jgmahoney and 11 guests
