KCStudly wrote:I don't understand the root cause. If the walls were bowed slightly (curved from floor to ceiling), or racked (both leaning to one side or the other... parallelogram) I'm not sure how that would have caused this and have the hatch still line up with the side of the wall.
It is important to understand the root cause in order to make an informed decision on the remedy.
Are the walls now straight and square to the floor?
Is the gap the same on both sides?
Socal Tom wrote:There are several contributing factors,
2 The hinge was originally cut about 2 feet further forward, I reattached the top as best as I could, closed that seam, then cut a new hinge point at the existing location.
3 I had to do a little trimming to get the hatch to line up well with the body when I installed the hurricane hinge.Thanks
