alaska teardrop wrote:Ken, It seems to me that your unit would be more efficient if it had more interior surface. Maybe a larger tube with baffles or a multiple tube heat exchanger.
Anyway, your 20# propane tank should not freeze or even run slow at -1*. Pure propane doesn't start to freeze until -40*. Depending on where you live & the season, you may have a mixture of LPG & butane. Butane freezes at 31*.
Another possibility is that your regulator is frozen. The regulator should be installed with the vent downward so that moisture will drain. If the vent is on top, moisture will collect on the top of the diaphragm, freeze & stop the flow of propane.
Fred
KennethW wrote:The tank is one I use on the grill. Their is no regulator just a 20# tank ,a Mr heat adapter hose and the propane torch. I think it might be freezing in the torch orifice were the gas expands.I might have to use a side burner off a gas grill that I would have to mount it in a hood and regulator.
Do they mix butane with propane for grill use in Minnesota?. The tank is one I use on the grill.
