jgrote wrote:I don't want to use wood because I've made a point to have no wood on the bottom of the trailer. I thought I would be able to find something like that in PVC but have had no luck. My goal is to have nothing on the underside that can rot.
jgrote wrote:I was thinking some kind of plastic, composite, or rubber.
bdosborn wrote:jgrote wrote:I was thinking some kind of plastic, composite, or rubber.
I worried about using wood on my first build too. Then I started sticking my head under every trailer I saw, new and old, to see how the floor was holding up. To my surprise, older pop up trailers often had unpainted plywood floors. 40 year old trailers and the plywood was fine. It's just not worth the effort to use something other than wood, the rest of the trailer will fall apart long before the floor does (IMHO).
P.S. I used paint stirrers to shim mine...
jseyfert3 wrote:Did they use a special type of wood though?
I got fancy on my second build and used wood floor paint.
MtnDon wrote:Why not use strap steel of the appropriate thickness? The frame is steel.
jgrote wrote:The bottom of my floor is going to be FRP, then 2x2 framing, then plywood on top.
