225's teardrop
225's teardrop
Postby 225 » Sat Jan 25, 2014 11:42 am
I am definitely tired of building TD's. Some people take great joy in building them. Not me. I'd rather be camping in it than working on it. However, through trial and error, I've learned a few things. I've learned what I want and don't want. And what works for me and what doesn't. So after much planning and figuring, I promise this will be my last one.
So onto the history:
#1. Didn't even finish it. Why? Divorce.
#2. Fully built. There were few flaws I didn't like.
- Trailer sat too low to the ground. Lots of rubbing when I when over something. I used torsion axles. Next I'll be going to springs.
- I didn't box in the ends of the frame. It was just ugly.
- Better A/C placement. Still working on this one.
- Stereo took up too much space. So did the A/C.
- Liner on the roof (in the cabin) was a pain. And could have turned out better.
- Doors. I only had one. Needed two. And I should have placed them as low as I could, they hurt my butt when getting in and out.
Here she is, sold to a nice couple in Texas.
Not sure if I'm going with bed liner again. Wish I could find a good aluminum supplier in Louisiana. And I'm keeping the same trailer dimensions, but maybe a different profile. Not sure yet.
But probably another Benroy. I love the profile so much and, but would love more galley space.
Anywho, I already ordered everything I need to start building the trailer.
More pics coming soon.
Re: My 3rd and final camper build.
Postby jgrote » Sat Jan 25, 2014 1:14 pm
I'm just starting the camper part of my first build, and hopefully only build. I get where you're coming from with the camping rather than building it. I love building things, but just can't find the time to dedicate to it. I started with a HF trailer, but modified it so much I might as well have just started from scratch. I plan on AC too, but am still not too sure where it's going. Do you have any plans for that yet?
jgrote
Postby 225 » Sun Jan 26, 2014 9:43 am
jgrote wrote:I'm just starting the camper part of my first build, and hopefully only build. I get where you're coming from with the camping rather than building it. I love building things, but just can't find the time to dedicate to it. I started with a HF trailer, but modified it so much I might as well have just started from scratch. I plan on AC too, but am still not too sure where it's going. Do you have any plans for that yet?
I had the A/C in the galley. I'm thinking about getting the climate right a/c.
Postby 225 » Mon Jan 27, 2014 11:30 am
I sent off the files to a friend who has a wood CNC. Profile and hatch ribs are being cut to save me loads of time.
Benroy_Side_Profile.skp
(58.46 KiB) Downloaded 258 times
Benroy_Hatch_Rib.skp
(55.58 KiB) Downloaded 180 times
Postby ps477 » Thu Jan 30, 2014 4:19 pm
225 wrote:I sent off the files to a friend who has a wood CNC. Profile and hatch ribs are being cut to save me loads of time, seen here.
How long do you anticipate this entire project taking you?
ps477
Postby 225 » Thu Jan 30, 2014 11:41 pm
ps477 wrote:
225 wrote:I sent off the files to a friend who has a wood CNC. Profile and hatch ribs are being cut to save me loads of time.
With my job, I have two weeks off at a time. I can probably get most of it done in 4 weeks off time. 6 max.
Re: Grasshopper style teardrop camper build.
Postby 225 » Sat Mar 08, 2014 2:22 am
In between work and doing some traveling this winter, haven't had time to start on the trailer yet. Hopefully next time off, I'll get the trailer frame at least built. Another reason I haven't started is because I didn't have my mind made up on which design I wanted. I'm pretty sure I am going with a Grasshopper clone.
Like this:
Here is my design:
I've already ordered 95% of everything I need besides wood and aluminum. I will be picking up the aluminum in Atlanta when I go on a motorcycle trip in a couple of weeks.
Postby mallymal » Sun Mar 09, 2014 4:31 pm
That's a very elegant redesign of the classic grasshopper shape. Not as slopey on the front which should give more inside space. :thumbsup:
mallymal
Images: 18
Postby pohukai » Sun Mar 09, 2014 5:41 pm
Maybe I read your 1st post a bit too literal? Didn't you want 2 doors? :D
I do like the grasshopper design, though.
pohukai
Images: 9
Postby Shadow Catcher » Sun Mar 09, 2014 6:50 pm
61605 This is ours.
Re: 225's teardrop build #2!!
Postby 225 » Tue Jun 03, 2014 1:11 pm
A while back I bought a TD template on eBay. I forgot I even bought it. So after digging through stuff I bought online when I got in from offshore, I remembered..LOL.
Since then, I never started my build because of my home brewery build and motorcycle stuff. After looking at the pics over and over, I think I'm going to use the template.
Here is the eBay link: http://www.ebay.com/itm/RV-TEARDROP-TRA ... 0738165041
And the trailer:
I'm going to try to make it as much as these as possible, but with my touch. Well, here goes nothing.
Postby aggie79 » Wed Jun 04, 2014 7:25 am
James,
You can't go wrong with either design. Both look fantastic. I'm assuming a/c is going to be installed in the galley area?
Postby Tommy2tone_1999 » Thu Jun 05, 2014 2:32 pm
Hey I think I just found an aluminum supplier in Zachary, LA
http://www.denversignsupply.com/ Click "Aluminum"
Make time for fitness and it'll make time for you.
http://TommyDoran.com
http://tommydoran.com/favor
Interview: http://goo.gl/Non1oR
Build Journal - http://www.tnttt.com/viewtopic.php?f=50&t=58395
Come find me on Facebook - http://www.facebook.com/tommy.doran
Tommy2tone_1999
Postby 225 » Fri Jul 11, 2014 8:28 am
aggie79 wrote:James,
Yes Tom. I'm going with the A/C in the galley like this:
Thanks Tommy. I will use them next week.
I finally ordered everything to build the frame. Hopefully next week when I get off, I can start on it.
And after much thinking, and mind changing, and more mind changing, I am going with the Grumman 2. I think my biggest obstacle will be doing the door instead of buying a pre-fab door. The pre-fab doors take away from the look of the Grumman. So hopefully, I can get it right.
Next week,I promise more pics.
Postby anon1 » Fri Jul 11, 2014 10:55 am
Hi 225,
Can you please explain more about your trailer #2 rubbing on things?
Like, what part(s) rubbed the ground and how high off of the ground that part was normally sitting? Was it just at incline/decline places where the tow vehicle might be going up into a parking lot and the back of the camper dragged? Was it at speed bumps/tables/etc?
Any details and real world info you can provide is appreciated.
Thanks.
[add] Do you know what the distance was from the axle to the rear of your camper and the height off the road to the underside of the rear part that might have drug? Thanks.
anon1
