Hi Krusty,
I think a slide out is a good approach and it can be as simple
or as complicated as you want. They are very popular with/in
the Australian camper trailer world. Some are quite ingenious
and inventive in their design and operation.
Some pics:
https://www.google.com/search?q=aussie+ ... s&tbm=ischYou should decide how you want to configure it - the overall size, what features
you need and want, the size it needs to be and so on. It doesn't have to be built
of heavy materials either. If you look at the various Australian ones, most are
made of sheet metal - aluminum or stainless steel or thinner thicknesses of plywood
A good example:
http://www.drifta.com.au/http://www.drifta.com.au/CamperTrailerKitchens.phpYou could build a frame out of 1x wood and glue 1/8 to 1/4 inch
"genuine" plywood to it for the outer coverings and various internal divisions etc.
I have a storage seat-stool/box from an older 1950s house trailer [@18inchx18inchx24inch]
that is made of 3/4 inch [true dimension] framing on the perimeter of all sides and
that is covered with 3/16 inch plywood on the four sides and the bottom. The top
opening perimeter uses 3/4 x 1 inch framing pieces. The top cover/seat is made out
of a piece of 3/4 inch plywood that is padded and upholstered. It is incredibly strong -
it's basically a cube-shaped torsion box. I'm sure it was just made out of scrap/cut-off
pieces of wood and plywood from the construction of the house trailer, and became a
something light and useful - a vanity seat/stool for use within it.
I'd check out the long drawer slides and the weight capacity you need for them. A 4-5
ft slide isn't cheap but would be worth it for the function and convenience it would give.
Of course, you'd want to have a support leg on the end away from the trailer once it's
pulled out to take some of the strain off of it, even if the slide-out can support the
weight itself, the end support leg is just extra 'insurance'. The "right" hardware or
part is most often worth any cost that is considered to be 'extra' or 'high', especially
if it makes what you are making easier to use or more useful.
You could also just do a simpler pull-out using rollers and guide rollers and a flip-down
end leg. But that would require you to be able to hold the weight of it as you pull it out
and before/while you deploy the end support leg. It just depends what your circumstances
and desires are.
Cheers,
Norm/mezmo
P.S. 'Just came across this Australian DIY Camper Trailer Build [What we call a tent trailer]
with a basic slide out kitchen. It's about midway down the build post. It slides out on plastic
covered runners with the 'trailer end' of the runners being tapered to aid in sliding it back
in.
http://www.campertrailers.org/holspeed_mk11.htm
