MtnDon wrote:That is similar to the Studor valve and it too works well for its designed purpose. Thank you. If I understand their operation correctly there is one deficiency for use in venting an RV holding tank. The valves are designed to allow air into the piping to permit easy non interrupted flow from the sink or shower down the waste pipe. In an RV the valve will open and allow air to enter the tank when the dump valve is opened. They will not permit air to escape from the holding tank when drain water enters the tank though. That is by design; they are meant for use in a building in place of a vent stack through the roof. The purpose there is not to vent smelly air out of the system, but to allow air into the pipe as the water flows from the upstream appliance to the downstream sewer or septic. In a home the valve would be located close to the fixture just as a standard vent stack would be. Studors are great for things like sink located in a kitchen island counter.
The way I see it in an RV with a holding tank, the holding tank needs a vent to the outside. Air must be able to enter the tank as it drains; something the Studor will do. It also needs a vent to allow air to leave the tank as the tank fills, something the Studor would not do. For that task the holding tank needs to be vented outside to avoid the problem of malodorous vapors inside the RV. The appliance or fixture should not need a vent because of its proximity to the holding tank. At least that is the theory I am going by.
Does that sound correct?
