Banjo wrote:On inspecting the interior plywood for removal to put in windows , wiring ,ect what I thought was phillips head screws to unscrew turned out to be slightly curled phillips head nails that you cannot screw out . The only way to do it is get a pry bar under the plywood and either pop them out or get enough pressure to unscrew them . I have not gone that far yet to remove the plywood as I am not ready yet to do it . I also found that a T 20 or T 25 star bit will not fit the screws on the outside skin in case I have to loosen the skin for window installation to weld a frame in . Does the factory have a secret bit to fit these screws ? Has anybody run into this problem ? Thanks Bob
